Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
DIY Hood Cylinder
Not wanting to infringe on the group buy for the same item, I'll start this thread(...thanks to the encouragement of Charles and Brick!)
Ordered the parts today: MSC #: 00483743----------------$15.43----- 30# cyl w 7" stroke MSC #: 32912198---2@.72-----$1.44------- ball stud MSC #: 32912206---2@.24-----$0.48 -------retainer clip total---------------------------------$17.35 They should be in Thursday, if so I'll have it installed that night. I plan to make a bracket off or the motor mount and another off the hood hinge mount, utilizing the existing bolts, so no drilling and simply a bolt on with no under the fender stud sticking thru to try to put a nut on. I ordered the 30# cylinder because I would rather have more rather than not enough pressure on the first try...I actually think the 20# would be the one but could actually be the 10#. A post on the group buy thread mentioned cheap isn't always the best, and that may be true, but in this case I have to say these cylinders are every bit the quality that the group buy will be getting, if not from the same manufacturer. I believe this will be the chrome plated cylinder, but not certain because picture doesn't always match (but the cheaper ones show black). Did I mention the total price could be lower by about $3 if someone wanted to scrimp (buying the ends separate from the cylinder). Congrats to the ones going with the group buy, I'd say they probably buying a good product, and anyone in the business has to make a profit (they're asking a fair price). I'm just offering some savings to the do-it-youselfers at the same quality level (minus the 10 hp sticker) because right now I'm not in the business. If the parts come in, pics will be posted at least by Saturday....with no drilling or reaching in the fenderwell.
____________ Old School Cobble Jockey
Hook it up!!!
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
I am not trying to be a dick and burst your bubble, but it will not work there... the cylinder is going to colapse befor the hood shuts fully... they tried that in that position you mentioned
#4 | |
der Zeck
Oh did they have brackets.... many many brackets.... Give it a shot Churp, worst that can happen is you have to exchange it for a different one...
Purchased brackets won't work....that's why I have to make one (actually 2 because I won't drill holes in a car unless absolutely needed). This is so simple from what I've done every day for the last 25 to 30 years, that I can't believe anyone would doubt this type of project. My only concern is the pressure of the gas spring, which will work , but may work better with less.
Have faith, theres millions of ways to do anything! Clean and functional are the main goals. There's no way I can improve function over something that works, I can sometimes improve ease of installation, and beauty is always in the eye of the beholder so some may like it,some not. We'll see in a couple days (just hope the parts come in). I really don't want to copy what is shown on the other post, so worst case if my brackets don't work I'll give these pieces to Brick (since he stated he was a little down on cash ) and he can mount them like the pictures of the group buy, all it looks like that's different is the plastic rod end down by the strut tower, about a dollar.
Black Yaris .....I apologize for the off topic on your thread. After rereading you 1st post there, realized how far off I was. I'll try to contain myself better.....
der Zeck
no hard feelings...
:: watching :: !!!
What happened to the original Hood lift post from Black Yaris? I've been trying to find it with no results...............
haha I tried the link in his sig but it don't work...says it's invalid or something
der Zeck
they pulled the thread
#14 |
Gotta play by the rules kids.
#15 |
o. Sorry to hear that. I was hoping to see a vid of the original. Make a new thread in the Classified section!!! ^^ iono just an idea n once again sorry for interfering with your original thread
#16 |
Hey Black Yaris, In your signiture with the redline racing it says "Lift kit coming soon". I know that's for a hood lift, but it reminds me, I'm thinking about going rally style with some extra gound clearance and a nice skid plate/light combo.
#17 |
Don't have the parts yet but the prptotype brackets are made. Painted them silver to show better in the pic's...and these are prototypes with extra holes, etc. The lower bracket is made way too thick, 1/8" material will do. At least you get the idea with these pic's....top hood hinge bolt removed then used to mount the top bracket, there is a relief in the bracket so the 2nd hinge bolt does not need to be removed but the bracket is restrained from turning by the bolt head.....the front motor mount bolt is used to hold the bottom bracket, which rises between the washer fill neck and the air conditioning check/fill block. The angle of the cylinder with hood closed is slight enough to not apply upward pressure. Don't see any interference points and dimensions should work.
When the other parts arrive it should take less than 10 minutes to see if they work....then it will be making purty brackets without all the holes, and purtier pic's (not too purty tho because my camera's crap). Edit: made a lower bracket out of 1/8" x 1" and it is too weak......1/4" x 1" like the prototype should be used.
#18 |
Look's like aluminum... Good work, can't wait to see the finished product.
| Canada Only - Maybe a $1000 enviro rebate on Yaris> | MDF | New YARIS Purchase Forum | 45 | 05-01-2007 08:17 PM |
| Need Someone to Test Fit VIS CF Hood | BLAZETIGER | Cosmetic Modifications (Exterior/Interior) | 22 | 04-27-2007 07:56 AM |
| Hood gasket | acrbill | General Yaris / Vitz Discussion | 0 | 01-05-2007 08:03 PM |
| Before you buy . . . check that hood! | woof | General Yaris / Vitz Discussion | 4 | 12-02-2006 05:14 PM |
| HELP! paint dings in the hood... | oktaren | Cosmetic Modifications (Exterior/Interior) | 23 | 08-01-2006 09:20 AM |
