![]() ![]() Drives: 06 yaris AT Join Date: May 2007
is Amsoil 0w-20 fine for me who lives at a place near the equator? Like 25-35 deg C all year round. Thanks!
![]() ![]() ![]() ![]() ![]() Drives: 07 Bayou Blue Liftback Join Date: Apr 2007
I personally would stick with the 5W-20. The temperatures in your area warm enough that they would not warrant 0W-20 in my opinion and might not protect as well as 5W-20 under heavy loads and higher engine temperatures.
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
it should be known, 5W-20 and 0W-20 have exactly the same properties in a warm engine. Only difference is when the engine is still cold, the 0W-20 will be a little more fluid. 5W-20 or 0W20 in very hot climate would be OK only if the engine is usually kept at low rpms.
#4 | |
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2007
My car is at 3800 miles, i'm prob gonna wait until after my 15k mile service to switch to Mobil 1, so at 20k miles i'll switch, that will give everything plenty of time to break in.
![]() ![]() ![]() Drives: 2007 Toyota Yaris S Sedan Join Date: Jul 2007
hi guys, as you'll probably know already, my 07 yaris has 325,000 miles on it. and i was contemplating on switching from wal-mart super tech synthetic 5w30 oil to mobil 1 synthetic extended performance 5w30 oil. i usually change oil every 5000 miles, which is about every 2 weeks for me. but i would like to start using the mobil 1 synthetic extended performance 5w30 oil and change my oil every 15,000 miles instead. what do you guy thinks? your opinions would be greatly appreciated. thanx!
![]() http://www.youtube.com/watch?v=YnTlNLz9Iqc http://money.cnn.com/galleries/2010/...le_cars/5.html http://www.subcompactculture.com/200...-miles-on.html |
#7 | |
I used to have more posts
Drives: '10HyundaiTucson'07Impreza Join Date: Jan 2007
and fyi we havent broke 17k on our 07. lol |
#8 | |
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
BTW, I grew up in Hallandale in the '60's (730 NW 1st St.) I still remember the military convoys going down the road towards the south during the Cuban missile crisis. Needless to say, housing density has increased a bit since I lived there....
#9 | |
![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
#10 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
The fact is, the ONLY difference is that the 0w protects better during very cold weather during start ups. As to operational oil temperatures (180f to 212f and above) the 5w and 0w both protect the same because they are both 20 weight on the high end of the viscosity range. So at hot operational temperatures, 0w-20 and 5w-20 provide the same protection. |
#11 | |
You're still confused
#12 | |
It's about the additive packages, and not the viscosity. Now as time goes on, more 0w-20 brands will be good for the Yaris, but today not all. |
#13 | |
Toyota (USA) Demands API approval
Show me where Toyota says do NOT use 0w-20 because of additive packages, but use 5w-20 and 5w-30 for the Yaris (1NZ-FE) because their additive packages pown 0w-20's...all I see in Toyota's TSB is that they will allow 5w-20 but NOT 0w-20 in the Yaris motor, and there have never been little footnotes about *additive packages* as far as I can tell, plus you've ALWAYS stated that the TSB states 5w-20 is okay, so "with that being said 0w-20 is okay because it performs exactly like 5w-20" without ever mentioning certain additive packages in certain oil brands being the deciding factor. And why would you use Amsoil 0w-20? It's not API approved...hmmmm...but the Amsoil XL 5w-20 is API approved ...bet that's another reason why the Toyota TSB says yes to 5w-20 and no to 0w-20. Bottom line: Until the TSB says yes to 0w-20 it's wrong to use it, but keep using it year round in southern California. ![]() You must wake up in a new world every day. How many times have you claimed that brand doesn't matter, that the cheapest discount synthetic will make an engine last just as long as an expensive synthetic, like Royal Purple? I'm not the one that's confused; I use API certified oil, and the proper viscosity, you don't.
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 04-24-2009 at 09:28 AM. |
#14 | |
ADDITIVE PACKAGE. For example, this is why SL grade 5w-30 can be run in car X but not car Y, yet BOTH cars call for 5w-30, but not ANY 5w-30. So if two oils are 5w-30 yet only one can be run in car X, why? ADDITIVE PACKAGE differences. There are cars out there that call for a particular brand of 5w-30 or 5w-20 or 0w-20 because not any brand will do even if the viscosity range is perfect....why? Additive package differences, again. |
#15 | |
However this thread is about 0w-20 vs. 5w-20. In regard to this particular and specific issue, brand does in fact matter because not all brands provide the appropriate additive packages required by certain cars. Now if one wants to use oils found in their manuals/TSBs (5w-20, 5w-30) in their Yaris then as long as the oil is either made by AMSoil or is API-SM certified, then BRAND DOES NOT MATTER. For example, when I run 5w30 or 5w-20 the brand of the synthetic does not matter. But for 0w-20 the only brands I will use are Mobile1 and AMSoil. This is the EXCEPTION, and not the rule. Hope this clarifies. |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 02:56 AM |
