Old 06-26-2007, 07:25 AM   #26
Motorhead6T5
Motorhead6T5's Avatar
Drives: 07 NCP96
Originally Posted by kimona54 View Post
ENTIRELY MISLEADING AND ABSOLUTE BLOODY NONSENSE!
You're living in the dark ages when automatic transmissions "lost power" through the design of the torque converters. That isn't the case today with Toyota's automatic transmissions.
In fact, many of today's automatic transmissions are every bit as quick as manuals, and are often quicker!
Don't be afraid to step on the Yaris' accelerator and you'll match the stick shift through the quarter mile, and you'll the clean the manual if the driver is even slightly off shift.
The only place, you may wish you had a manual is on the circuit when entering and exiting corners. But, even there, you can manually shift the Yaris' automatic tranny with some impressive performance.
There may be something positive to be said for the manual shift re drifting if the Yaris were a rear wheel drive car... but that's a moot point.
Furthermore, the Toyota automatic is every bit as fuel efficient and reliable as the manual, and over the long run will cost less to maintain.
Indeed, most Yaris automatics are getting better gas mileage than manual shifts due to the driving habits, capabilities, or inexperience of manual shift drivers.
Any argument against purchasing the automatic transmission in favour of the manual shift based on superior performance, better gas mileage, or reliabilty is just plain uninformed foolishness!
The only viable reason for purchasing a manual transmission is the simple fact that you like to shift and/or it makes you feel one with the car and more in control on the road. However; these are all purely psychological factors that not all drivers can relate to.
http://autos.msn.com/research/vip/Sp...aris&trimid=-1
If you would click this link you will see a performance section,compare the sedan m/t with the sedan a/t.
M/T 0-60=8.84 1/4 mile=16.97 1/4 mile trap speed=84.00
A/T 0-60=10.29 1/4 mile=17.96 1/4 mile trap speed=77.30
That almost 7 mph difference shows a huge differance in power put down to the ground,and the 1 sec quicker in the 1/4 seals the deal.
You can tell yourself whatever you want to help yourself sleep at night though.
Motorhead6T5 is offline   Reply With Quote
Manual Transmission...Safety Issue!!! twocvforme General Yaris / Vitz Discussion 189 10-31-2010 12:00 AM
Change automatic to Manual Blenjar General Yaris / Vitz Discussion 11 06-14-2007 07:02 AM
JDM Center Console Box + Manual Transmission bigsky2 Cosmetic Modifications (Exterior/Interior) 5 11-28-2006 09:08 AM
Is that bad for automatic transmission? hans_fh General Yaris / Vitz Discussion 9 11-20-2006 08:25 AM
Manual vs. Automatic ?? YarisBlazer General Yaris / Vitz Discussion 12 08-13-2006 08:14 PM
