Old 06-28-2007, 08:03 PM   #1
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
Originally Posted by drifto View Post
if you want quiet and dependable, go oem. if you want performance or cheapy breaks then squeaks are going to happen, esp. any time it rains.
My brake squeaks when it's rains. And i only got 25k miles. Original Toyota Brake Pads.
I took it back to dealers and they gave me some bullshit answer like you have to upgrade to Drill/Slot BRAKE ROTORS + Performance pads to stop squeaking.
I mean do Drill/Slot BRAKE ROTORS worst it? if yes then i will go ahead and upgrade my.
jamal1984 is offline   Reply With Quote
Old 06-29-2007, 01:51 AM   #2
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
lol thats a crazy dealership man. brakes squeak sometimes like i said. it doesnt always mean there is a problem. performance pads usually squeak more b/c the fricion material used is meant to withstand heat better. oh and to say you need slotted/drilled rotors to solve the problem is hillarious. usually high performance pads have more metal composition causing more squeaks. after it rains most cars will squeak for a bit till the rotor and pad surface dry up. it will happen after a car wash too somtimes, so dont stress it.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
brakes - how may km. Rabbit General Yaris / Vitz Discussion 9 05-29-2007 12:35 AM
Brakes and Shocks question jamal1984 DIY / Maintenance / Service 6 03-18-2007 05:26 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 06:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 05:17 PM
Brakes jcove Performance Modifications 4 05-03-2006 12:59 PM
