#1 | |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
the less side wall you have the lest cushion you have, hence the larger the wheel the less side wall you have room for
SPONSORED BY
![]() Drives: Toyota Yaris Base Sedan Join Date: Jun 2007
My tires are 215/40ZR17's and the recommended pressure is 35. I'll take it down to that pressure to see how it feels. Just don't want to dent the rims. How common is this? Think I should be worried?
#3 | |
Lonesome Cowboy
any rim can be bent slamming into a pothole, you are more likely to bend a rim when you are running a lower side wall, way more likely dodge potholes don't run you tire pressure to high, it is dangerous keep pressure between 30-35
SPONSORED BY
| Power upgrade (pictures). | W.A.S.P | DIY / Maintenance / Service | 91 | 11-15-2017 10:32 PM |
| Finally! | KittenRD | New YARIS Purchase Forum | 6 | 01-01-2007 09:16 PM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 04:24 PM |
