Parallel Parking Pro
I did some Googlesearching and came out more or less with the ratio of 1:4 (ie 1lb rim weight lost is as good as 4lbs static weight).
It is a best-fit rule of thumb that some people use to simplify the performance advantage of lighter cars.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#2 | |
There is a range of claims but 1:4 sounds a little less optimistic than a 1:7 ratio. My scanning of other internet forums suggests 1:4 is more commonly accepted.
Then maybe my calculation of less than 1% is correct? If the stock wheel weight is 15-16lb and you went with a 10-11lb, then you would save ~5lbs per wheel, or 20lbs total. 20x4=80lbs... imagine a race between two stock Yari...the only difference being, one the driver weights 120lbs, the other 200lbs ... sounds like a dead heat to me?
| Feedback on these wheels | BulletProofAuto | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 06-04-2007 08:09 PM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 06:55 PM |
| Do bigger wheels and tires improve performance | Driver | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 10-14-2006 06:01 PM |
| Enkei RZ5 wheels on Liftback | kennywhy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 09-23-2006 04:22 AM |
