Old 07-20-2007, 12:34 AM   #1
squareback
Drives: Non-Yaris
Originally Posted by jdium View Post
Handles like butter? Doesn't sound too good to me...and as a Yaris owner, I don't think a Yaris can ever be described as "mean looking"...
Handling on these cars can be best improved with sticky rubber. There is very little room to add rubber, but you can improve the tackiness immensely from stock...
Okay, sorry. What I apparently should have written was something like this:
"I am sure the handling of the car is drastically improved over that of a stock Yaris. It's probably smooth and sweet."
Sorry for the butter confusion.
And are you suggesting the meatier tires make the Yaris look less mean? Any car with significant rubber will look meaner than stock.
Oh, and last time I checked, Toyo RA1 tires ARE sticky rubber. Hence, the handling on the car in question is improved. I don't know if that car ever sees any real track time (doubtful), but if it does, I'm sure the professionalism of the company has led them to make sure the car has plenty of clearance for those meaty, sticky tires. On the street, they would certainly be excessive.
squareback is offline   Reply With Quote
Old 07-20-2007, 01:58 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
[QUOTE=jdium;112676]...and as a Yaris owner, I don't think a Yaris can ever be described as "mean looking"...
Well... unlike the Honda Fit, which looks like a timid frog, I also think the Yaris HB looks somewhat mean with a set of wheels and some aggressive tread... kind of like a little bulldog!
Old 07-13-2007, 04:04 PM   #3
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
You got it.
My xB stayed stock for 2 weeks; my Yaris will probably be less than that.
Old 07-16-2007, 08:30 AM   #4
ya_RS
ya_RS's Avatar
Drives: 07 RS
from what i can see in the new siphon mag
wheels: 15x7 / +38 offset with 4x100 bolt
tires: Toyo RA1's 225/50 ZR / 15
Honda to Toyota... lets see how this plays out
ya_RS is offline   Reply With Quote
Old 07-16-2007, 09:33 AM   #5
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
That would explain the oversized look to the tires.^
SPONSORED BY
Old 07-16-2007, 11:25 AM   #6
Thirty-Nine
Ah ha! Thanks!
Old 07-16-2007, 12:33 PM   #7
kimona
kimona's Avatar
Well, that's alot of rubber up front on the Yaris.
I think we could expect some real rubbing issues on a lowered daily driver!
Up front, 205/55/15 on a 7", ET38 will stick out about 2mm's.
But a 225/50/15 will bulge an additional 10mm outside the front fender!
Old 07-16-2007, 01:04 PM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
225/50R15's do not stick out at all from the fender when ran on a 15x7 on a +38 offset... that was my first setup... I was not lowered, but they did not stick out at all.... I could have done the TRD drop 1.1F, 1.3R and been fine w/o rubbing... but I wanted to go lower, thus why I opted to go with my 17's
Old 07-16-2007, 12:57 PM   #9
ya_RS
ya_RS's Avatar
Drives: 07 RS
most likely set-up super stiff shocks to keep the bound and rebound to a minimal
Old 07-16-2007, 02:55 PM   #10
kimona
kimona's Avatar
Sorry to contradict you, but anyone running 205's on a 7" rim with a +38mm offset MAY have a tad of a poke UP FRONT depending on the brand of tire installed.
There are a lot of guys on Yarisworld running this setup. Let's hear from them.
Hence, a 225 on the same rim will certainly poke out UP FRONT. I'm not talking about the tread here, but the tire sidewall.
Old 07-16-2007, 06:06 PM   #11
Thirty-Nine
I personally wouldn't put anything wider than a 205 on a Yaris. More rolling resistance = less milage. Plus, I think a 205 is plenty of footprint for handling on such a small car. Maybe for racing or autox, but not for daily driving.
Old 07-17-2007, 06:34 PM   #12
ya_RS
ya_RS's Avatar
Drives: 07 RS
i agree 205 is just as big as i'd go... the TTE's in 16's are wrapped with 195's
Kaminari Yaris in Modified Magazine eTiMaGo General Yaris / Vitz Discussion 2 04-16-2007 12:04 PM
Kaminari YARIS Pics coming........... DJFMedia Cosmetic Modifications (Exterior/Interior) 48 10-27-2006 01:37 AM
