Old 07-23-2007, 08:56 AM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
as peter said 40-42 is the best +45 in the front and +38 in the back would be pretty phat with 205/40's all the way around
Ditto.
Depending on the tire, ET38 may poke out a bit up front, ET40-42 would be much better, and ET45 would give you a tiny tuck up front which usually looks best and eliminates most rubbing problems.
If you're not lowered, go with 205/45's. If you're lowered, you may want to go with 205/40's, especially if you run ET38's.
However, you could manage 205/45's if you're lowered and you have chosen the proper offset.
Old 07-23-2007, 09:11 AM   #2
flighttekchris
flighttekchris's Avatar
Drives: 2007 Yaris 3door
Originally Posted by kimona54 View Post
Ditto.
ia am looking at the +40 as an offset, as i have no plans on lowering the car from stock,
PetersRedYaris can you post some pictures of you tires so i can see how they fit? what offset do you have?
BTY i am new to this.... what is "offset" anyway?
thanks
chris
flighttekchris is offline   Reply With Quote
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 09:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 07:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 07:01 PM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 05:22 AM
