Old 07-26-2007, 04:06 AM   #1
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I have the Tanabe NF and all four of the sides are the exact same distance from the ground to the middle of the wheel well making it level. just depends on your tastes. The NF spring give you a more stock ride without body roll and the DF's give you a lower drop with a stiffer spring. I am not for sure about the Tein springs, but I have the NF's on my sedan and it rides smooth with no rubbing what so ever on stock tires and wheels.
slvryaris is offline   Reply With Quote
Old 07-26-2007, 08:46 AM   #2
kurokoma-kun
Drives: 2007 Yaris HB
Did you keep your stock struts? I plan to do the NFs for now too but have read that increased spring rate means my shock/strut will wear out quicker.
my yaris, kurokoma-kun
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 08:21 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
