#109 |
return of the comeback
Drives: white '08LB..very nice,i like Join Date: Mar 2007
ey kevin, do you guys plan on comin out wid other yaris parts anytime soon? the shifter was a breeze to install even without the required tools and i love how the feel on it.
#110 | |
![]() ![]() ![]() Drives: 84 GTI, 90 GTR, 97 Si Join Date: Mar 2006
Thanks! Kevin TWM |
#111 |
This stuff is great.Unfortunately mine needs some minor adjustments in the middle part, cause it is a little bit smaller than the OEM ''hole'' and I have to use something to make up for the smaller part.
#112 |
I installed my TWM short shifter last week on my 2007 Yaris hatchback. Do not regret the install. Great shifter. Dremel tool makes it very easy to split the spring clip. Prying off the clip would be a hard task. There is no room to insert a thin blade screwdriver between the floor shifter and the spring clip. Hats off to Toyota for a great factory install job. Be aware not to loose the small plastic locking piece the attaches the the left hand control section cable rod adjuster case.
#113 |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
only if you do not cluch properly, long as the clutch is engaged while shifting you shold be ok
#114 |
i will know soon :p
#115 |
Hot2Trot
Drives: 2007 Yaris Sedan Aero package Join Date: Dec 2006
hey guys i installed a TWM 2 weeks ago and i was complaining about 3rd gear grinding. The shifter was installed after the grinding but if you have a synchro problem get your tranny looked at first. toyota hates the short shifter. i reinstalled my stock one before i took it in but they knew right away i had fucked with it. Luckily i work for the dealership so i just got a few rolling eyes. But the ss KICKS ASS! i did the bushings too and they are worth it. who knew that 4 mounts could make a difference. THANKS TWM
When I see my Yaris, I just thank God I have a HUGE DICK! |
#116 | |
Glad to hear you guys are enjoying the short shifter and base bushings! Kevin TWM |
| TWM Performance Short Shifter | Idjiit | Performance Modifications | 16 | 12-16-2006 06:10 PM |
| TWM Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 9 | 08-28-2006 04:37 PM |
| Custom short shifter | ChinoCharles | Performance Modifications | 13 | 08-20-2006 04:52 PM |
| First to install twm shortshifter!!! I think... | SamDaYarisMan | Performance Modifications | 7 | 08-11-2006 10:33 PM |
| TWM Short Shifter/Shift Knob Sale! | TWM Performance | Performance Modifications | 0 | 07-17-2006 06:08 PM |
