Old 08-08-2007, 09:15 PM   #1
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
positive trigger = a +12V wire is given power when the switch is on.
negative trigger = the ground wire is active when the switch is on.
toyotas are mostly negative triggered. Makes the harness a little different for constructing.
The high beam will get the common 12V and the high beam ground
The low beam (HID) will use a relay harness which will use the low beam and high beam grounds as a trigger wire.
Black Yaris, what are city lights? Do you mean the parking light? Is it a bulb that turns on when you flip the headlight switch one notch, and stays on during the low-beam switch?
taKuto is offline   Reply With Quote
Old 08-08-2007, 11:48 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
what you are calling a positive trigger is a normal neg(-) ground system
what you are calling a negative trigger is called a pos(+) ground
City lights are the these, I had this pic laying around, to explain city lights to someone else
Old 08-09-2007, 08:21 AM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The reason I use three relays is so I can flash the high beams without the HIDs coming on. Worth the effort, I think.
Old 08-09-2007, 09:57 AM   #4
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
When is that city light active? I don't have one for my echo so I wouldn't know anything about it.
Old 08-09-2007, 09:28 PM   #5
Violin
Violin's Avatar
The first position on the light stalk turns it on, the next turns on the headlights. I used it (labled "arking lamp circuit" on my schematic) to trigger the one relay - if I used the low beam, they wouldn't turn off without shutting off the car. If Canadian models lack a city/parking lamp, my harness wouldn't work.
Old 08-10-2007, 10:14 AM   #6
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
We have parking light as well in Canadian models.
GabL is offline   Reply With Quote
Old 08-22-2007, 06:19 PM   #7
GabL
I want JDM bumpers!
GabL's Avatar
Is it possible to wire the Fog Lights to become DRL? Just a though after talking to my friend. He did a retro fit to his Civic SiR with Audi A6 projector, and he wired his Fog to become DRL with the use of relays... I will ask him for more detail on that.
Old 08-24-2007, 02:35 PM   #8
R0ME0
Drives: '00 Toyota Celica GTS Turbo
GabL I went through a similar dilema with my Celica. i'd just retrofit a custom HID setup for the headlights with some grommets thats what i did and its works like a beauty. Also as someone pointed out that the 3prong is for a leveling switch. Pretty easy to wire up. If you're interested let me know I can teach you how to hook it up. It does wonders in the Celica! I might have to do this for the Yaris now. Do you have a link on where to buy these headlights? Additionally do you have more pics of the headlights? Is there no longer any permenant amber on the headlight just in the bulb? Please let me know. Thanks!
R0ME0 is offline   Reply With Quote
Old 08-28-2007, 06:10 PM   #9
GabL
I want JDM bumpers!
GabL's Avatar
R0ME0, do you still have the wire diagram of how you wire up your Celica? I do want to make the fog light the DRL and keep everything there.
I'm also interested to know how to wire up that auto leveling switch? Please post some pictures if you can. Thanks!
I got the headlights from Taiwan Yahoo auction as mentioned (tw.bid.yahoo.com). It doesn't have the permenant amber reflector at the side, also the side parking light is not on this headlight also. I will try to post some more pics later!
Old 09-23-2007, 04:58 PM   #10
acdaazn
Drives: Toyota
So whatever happened to this project?
acdaazn is offline   Reply With Quote
Old 09-24-2007, 12:06 PM   #11
GabL
I want JDM bumpers!
GabL's Avatar
It's on hold until I find out how to get the circuit working. hahaha!
Trying to get the fog light to become DRL, with on/off switch still function. My friend did that to his Civic SiR, so need to find time so we can sit down and look at it.
And thanks for following up, I will definitely post up some info once I get it done.
Old 09-24-2007, 04:03 PM   #12
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
Well, If i understand the DRL circuitry correctly, it's an independent wire that hooks to the headlamps power. So, in theory, you can re route the DRL power to the foglights. My Yaris doesn't have neither DRL nor Foglights, so I can't vouch for this to work. In theory, however, if you can find where the DRL circuit hooks up to the headlamp harness, you can just cut this connection and connect it to the foglights one instead.
TrancosRt is offline   Reply With Quote
Old 09-25-2007, 10:37 AM   #13
GabL
I want JDM bumpers!
GabL's Avatar
I think it's the other way, as there is only one wire going to the bulb, which is a H4 bulb, and it is the DRL module that regulates how much power to go to the bulb, i.e. DRL or Low Beam. So I cannot just hook this wire to the fog to make it DRL, else I will lose the Low Beam wire. This is how I understand the circuit diagram from the DIY section.
Old 08-02-2007, 11:02 AM   #14
GabL
I want JDM bumpers!
GabL's Avatar
Originally Posted by vasilios View Post
can i ask from whom/where did you buy those, and how much did they set you back?
From Taiwan, yahoo auction.
It costed me about $650 CDN + shipping.
Old 08-02-2007, 12:07 PM   #15
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
$650 is not bad at all... I was under the impression that HID and reflectors = not a good idea... I'd like to see these installed and turned on. : )
These headlights are designed for factory HIDs.
Not every headlight housing has a projector lens from the factory for HIDs. Prius, Navigator, QX56 are just a few examples of factory installed HIDs, without a projector lens.
Old 08-02-2007, 12:26 PM   #16
GabL
I want JDM bumpers!
GabL's Avatar
Same as my '00 TL
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 08:55 PM
Southeastern Power Package with Alloy wheels? Where is my Yaris? New YARIS Purchase Forum 0 03-23-2007 08:40 AM
convenience vs. power package jeff_o General Yaris / Vitz Discussion 25 10-17-2006 11:04 AM
Is concenience package and power package the same thing on liftback ? YarisBlazer General Yaris / Vitz Discussion 4 07-22-2006 12:58 AM
Waiting for the Taiwan Yaris heybai General Yaris / Vitz Discussion 13 03-12-2006 08:26 AM
