Old 10-08-2014, 10:17 AM   #1
Originally Posted by Jerkratt View Post
I re grounded the fog light wire. Fogs still work for me
Exactly. There is a DIY on here for disconnecting the DRL module and jumping the one wire to re-enable the fogs. All other lights (and the ebrake indicator) will work fine with it disconnected. The ebrake is actually just an input to it, so you can turn off the DRLs when parked
Old 10-09-2014, 10:54 PM   #2
JustPassinThru
Drives: No more Yaris
Years ago I had a Matrix with those lights.
I found by putting a shunt on the Parking Brake switch, it would put the DRLs out - if you switched on the shunt BEFORE taking it out of gear (if you waited until you were in gear, the DSLs would stay on).
Only downside is that the BRAKE warning light would be on. Actually not a bad idea, to warn you that you've got those DSLs off.
JustPassinThru is offline   Reply With Quote
Old 10-09-2014, 11:05 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yup used that trick on my Mazda with yaris its easy plug and play , just unplug
sent from my S4 on Mars
Old 12-16-2015, 03:05 PM   #4
spiceyhotwings
Drives: 2009 Yaris RS 5 door
Where is the DRL relay located?
On my 2009 Yaris RS could you please tell me where to look for the DRL relay?
my new 2009 Yaris RS 5 door
spiceyhotwings is offline   Reply With Quote
Old 12-16-2015, 03:37 PM   #5
Rigaud
Drives: 2009 Yaris
It's illegal to remove the DRL in Canada.
Makes no sense anyway to want it removed.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 12-16-2015, 03:59 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
And your point is lol
I use my lights when need it I see no point of burning my bulbs out... My car and my opinion.
Sent from my Samsung Galaxy S6
Old 12-16-2015, 07:33 PM   #7
Rigaud
Drives: 2009 Yaris
Not worth explaining.......you couldn't understand.
Old 12-16-2015, 07:52 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
And you are? Sorry but most if not all the stuff we do to our car's are illegal.
Old 12-16-2015, 07:56 PM   #9
Rigaud
Drives: 2009 Yaris
I obviously know that. Been doing real mods on cars for over 30 years. I simply pointed it out. Did I write not to do it? Nope. Did I say it was safer to keep lights on? Nope.
Chill out and relax a little. lol
Cheers ;)
Old 12-16-2015, 04:01 PM   #10
kimona
kimona's Avatar
Drives: 2014 White VITZ
Agreed. What possible reason would someone have to disable DRL's? It's not as if they negatively affect the car's performance or visual appeal in any way. Besides, DRL's are a proven safety feature.
Old 12-16-2015, 06:19 PM   #11
spiceyhotwings
This is why!
I have after market HID headlights (Hi/Lo). Disabling the DRL relay would give me an option of keeping my HID bulbs off during the day. It keeps things way cooler as those HID's get HOT. I wouldn't have to worry about things melting on long trips 5 hour plus or more. This would really add to the length of the life of the bulbs too. I would just turn on my LED running lights that are connected to my parking lights. I would still have my super bright LED DRL on without wearing out my HID's and keeping things cooler. I care about being visible! I would just turn on my headlights (maybe even on HIGH beam) if I needed to be seen even more in the day. So basically I would be driving around most of the time with my (parking lights/LED DRL) on. My cob LED DRL's look way better anyhow and they're freaking bright!
Old 12-16-2015, 07:50 PM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
HID's is one main reason it's why I disabled mine.
Old 12-16-2015, 08:20 PM   #13
kimona
kimona's Avatar
I get it.
Old 12-16-2015, 06:15 PM   #14
tmontague
tmontague's Avatar
I'll try and find a pic and let you know what connector it is to unplug. It is a white connector located under the drivers side dash just beside the radio side (right side of steering wheel). Unplug it and you will disable the DRL's. I believe the connector is vertical in orientation as it is long and narrow.
There are various reasons to disable your DRL's. I disabled mine when I hooked up my projectors HID's. The DRL's were causing my HID's to run all the time which is useless, uses excess electricity and prematurely burns the bulbs. This also allowed me to hook up my Halo's to be on all the time with the ignition and that way only those are on in the daytime.
Old 12-16-2015, 07:26 PM   #15
bladesmith6
Drives: 2007 yaris HB
They are not a proven safety feature, if you need headlights on during the day to be seen you need your eyes checked and your license revoked. Government propaganda plain and simple.
bladesmith6 is offline   Reply With Quote
Old 12-16-2015, 10:43 PM   #16
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
I love the DRL on my 2015 SE, mainly because they are LED with long bulb lifespans - and they do look very sharp with the design of the vehicle. I like that Toyota kept them simple, elegant and short (4 bulb each side), rather than those crazy, overdone designs that I see on some other vehicles. I also like that I can run the DRL with parking lights during my early morning commute, and not have to waste main headlight bulb life - since I can see my surroundings fine in the morning twilight, and just want to be sure that others can see me just fine - and you can't miss those pure-white-light LED "little angry eyebrows" coming at you.
Also, I DO notice other cars on the road more when they have DRL on - certain cars to the point of actually being obnoxious (overdone LED's). Also, certain colors of vehicles are more prone to be overlooked by the human eye even during prime daylight hours, and DRL can make the difference in being noticed before someone pulls out in front of you, etc. - especially under certain lighting/weather conditions. It's amazing how many people around here drive with NO lights on in the early morning or when it is very nearly dark. They are just asking to be hit.
Kalispel is offline   Reply With Quote
Old 12-17-2015, 07:30 AM   #17
tmontague
tmontague's Avatar
Every since the constantly lit up dashboards came into production people have been leaving their lights off constently here in the GTA. I see at least 2 cars every day on my way home with no lights on in the dark.
Don't even get me started on the lack of awareness people have to turn on their parking lights in huge snow falls, fog, torrential rain etc. The quality of drivers where I live is getting to be abysmal. People have no pride for the way they drive or their cars now a days.
Old 07-13-2016, 04:14 PM   #18
tmontague
tmontague's Avatar
The connector is located under the dash on the drivers side. Lie on your back and look up under the dash. Closest to the radio you'll see a white connector (is a pretty decent size), unplug that and you'll disable the DRL's.
To make led's your DRL's wire it to your windshield washer fluid 12v wire which is located on the side of the resevoir.
This allows you to not have to go through the firewall to access ignition switched 12v power
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 04:12 PM
