Old 04-17-2007, 02:31 PM   #1
rage2
Drives: 07 Black Yaris 5D
You've been telling people it works without even measuring what the wires are yet? If you've ever looked at an ECU harness, they have the most bizarre colors for ground or power. NEVER EVER guess a wire is ground because it's black, or a wire is power because it's red.
I don't know foglight wiring, so I can't answer that question.
rage2
My Yaris Diary - All about my new Yaris!
My Blog - F1 News, Hotties, and Random Crap
My Site - Beyond Car Forums
rage2 is offline   Reply With Quote
Old 04-17-2007, 03:29 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
actually read on!!
i havent told anyone it works im saying it should work..there a difference there..i just really cant wait to do it on mine..again we are going in circles here..the method should work..im giving a 99% only thing holding that back is the power running on the fogs... if hid ballast is relayed and it wont matter...even though YOURE confirming that there is 2 ground wire and one power it should still work! assuming the fogs has the same set up.. " switch fog ground to low beam ground". without check the voltmeter the worst thing that can happen should be blowing your fuse"... but hey "VOLTMETER" will be our best friend here.. im waiting for "VIOLIN" to respond maybe i dont have to use it! well see...
Old 04-17-2007, 06:21 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
How about starting a new post on this subject..
Old 07-28-2007, 10:07 PM   #4
Angry Andy
angryandy.net
Angry Andy's Avatar
Drives: 2007 Yaris 5-dr black HB
Send a message via AIM to Angry Andy Send a message via MSN to Angry Andy
Thanks for the easy mod, Chris. This will be the first mod I'll do when I pick up my hatchback later this week.
The issue of legality doesn't concern me in the least. I hate driving around with lights on all the time. And I hate driving around a well-lit town at night being fooled into the notion that my real headlamps are on. DRLs are the most useless passive automotive safety feature ever.
Angry Andy is offline   Reply With Quote
Old 08-07-2007, 08:05 PM   #5
Christopher
Cobra
Drives: '07 3-door
Thanks for the info!! I assume the headlights still go on and off by using the switch on the stalk? Chris
Christopher is offline   Reply With Quote
Old 08-20-2007, 07:46 PM   #6
tapuleo
tapuleo's Avatar
Drives: 2007 White Liftback
Got my Yaris in Washington and it has DRL's. I don't mind 'em though, but have been caught at dusk a couple of times because I forgot to turn the rest of the lights on. At night it's easier to not forget because I can't see anything else on the dash. :)
I suppose if I were a criminal, and wanted to sneak around in my Yaris at night, I'd want to pull the plug...or even a potential victim, hiding from a criminal, it'd be nice to be able to shut off the lights. I've seen way too many movies.
tapuleo is offline   Reply With Quote
Old 09-18-2007, 09:20 AM   #7
joey1320
joey1320's Avatar
Drives: Yaris LB
at first i didn't mind them but then i got my fog lights and i wanna just use the fog lights and the drl take away from the look of them... thanks!
joey1320 is offline   Reply With Quote
Old 09-18-2007, 09:35 AM   #8
Chris07LB
Chris07LB's Avatar
np.
Old 11-13-2008, 10:55 PM   #9
metalshark
MetalShark
Drives: 2008 Yaris LB
I got a warning ticket last night because of DRLs. When they are on I see lights but have no tail lights hence the pull over.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 11-15-2008, 04:38 PM   #10
Rotorheader
Drives: 07 Yaris Hatchback
That exact same thing happened to me last night, except I didn't get a warning ticket ~ just a "Go and sin no more." This morning, I removed the relay and did a quick test run; No problems.
Rotorheader is offline   Reply With Quote
Old 11-15-2008, 06:05 PM   #11
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Im gonna go do it right now....Whats the use of hiding from the cops at night if your DRL are as bright as your headlights. ^_-
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 11-16-2008, 09:59 PM   #12
Rotorheader
So did you do it???
Old 11-19-2008, 12:32 PM   #13
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Originally Posted by Rotorheader View Post
So did you do it???
Yeah I actually waited till I was at work...It worked on my 07 LB!
Old 03-06-2009, 04:20 PM   #14
RomGrr
RomGrr's Avatar
Drives: 2007 Yaris HB
Did this on an 07 liftback today. I'd say it's closer to an Atari cartridge than a pack of cigs, but to each his own
Thanks Chris. Easy as pie w/ the writeup.
RomGrr is offline   Reply With Quote
Old 03-07-2009, 06:54 AM   #15
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Any chance your insurance company would use the fact that you have modified your lighting on the car as a large loophole to deny you payment in case of accident?
Old 03-07-2009, 10:25 PM   #16
RomGrr
RomGrr's Avatar
Highly unlikely. There are no DRL laws here in the States. My state doesn't even do inspections any more. Lots of crap piles rolling around the roads around here.
Old 03-07-2009, 11:08 AM   #17
Chris07LB
Chris07LB's Avatar
No.
But in CANADA, anythings possiable!
Old 03-08-2009, 03:23 PM   #18
cyberfrogg
cyberfrogg's Avatar
Drives: Yaris Sedan S
Is there a way to add DRL's to my '07 sedan?
cyberfrogg is offline   Reply With Quote
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 04:12 PM
