Old 08-04-2007, 02:30 AM   #1
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
110mph, GPS verified. But it takes forever. It reads 175kph on the speedo.
nurburgring is offline   Reply With Quote
Old 08-04-2007, 08:23 AM   #2
leasaunce
Drives: Toyota Yaris
i've seen this video on youtube, where his yaris is placed on the roller, and the digital speedo would not go any higher than 199kph...
leasaunce is offline   Reply With Quote
Old 08-04-2007, 10:36 AM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
so far 110 on the GSP while playing with a beater 2nd generation integra that had -10 camber on the front wheels.
Old 08-04-2007, 11:35 AM   #4
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
What type of GPS? The reason I ask is that I am going to update my old unit and am just curious.
blacksan is offline   Reply With Quote
Old 08-04-2007, 01:39 PM   #5
ROCKLAND TOYOTA
TRIM HUNTER
^no i said gsp(garden state parkway).....
Old 08-04-2007, 09:09 PM   #6
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Mine goes over the 115 mark but never reaches the 120 mark so I estimate 117-118mph.
I Did it with 18'' on and tried it then with 15'' and it was the same only quicker hahaha
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 08-04-2007, 10:01 PM   #7
leasaunce
according to Toyota, the top speed of the 1.5L Yaris, 175kph.
Old 08-05-2007, 08:10 AM   #8
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
My GPS indicated a real max speed of 192kph (119mph). I am using a Garmin Nuvi GPS.
Because I was running a smaller than standard tire, the speedometer read a bit optimistic (200kph or 124mph).
Stands to reason that if I used a larger tire, I might be able to raise the real max speed a bit.
However at this speed, the engine is pretty much close to the redline cutoff, so I would say that is all the car would do given this combination of engine and gearbox.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 08-08-2007, 01:59 AM   #9
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Smile GPS is the most accurate way to measure top speed
the GPS does not lie ...
fu_im_from_texas is offline   Reply With Quote
Old 08-08-2007, 02:33 AM   #10
03Z33
03Z33's Avatar
Drives: TCR10
130 drafting my friends Cayenne S Installed one of these to remove the speed limiter:
That's according to the speedo though and I do run shorter tires, but it felt like it wanted to keep going a bit more
03Z33 is offline   Reply With Quote
Old 08-08-2007, 11:58 PM   #11
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
You have earn the kamikaze award hahah what the hell ur doin 130mph on a yaris hahahah ur nuts
Old 08-09-2007, 12:08 AM   #12
03Z33
03Z33's Avatar
Drives: TCR10
Trying to keep up with traffic the freeways here are CRAZY people think it's the autobahn or something as soon as you get out of the city
Old 08-09-2007, 02:01 AM   #13
Pars
Drives: 07 Yaris Liftback
Yup, I hit my speed limiter hard the last time I was that high. It did feel like it had more to go.
Pars is offline   Reply With Quote
Old 08-08-2007, 05:02 AM   #14
cleong
cleong's Avatar
Yup, a little bit more accurate than the speedometer given the variances of tires we use.
Some would say there's other better options but none are as easily accessible to the average driver as a GPS unit.
TRD Blue brake pads
DC Sports header
Old 08-09-2007, 11:58 PM   #15
Pavel Olavich
Drives: 2007 Yaris LB
Nope...going larger in the tire DECREASES torque at the front driving wheels...you will lose speed.
Pavel Olavich is offline   Reply With Quote
Old 08-10-2007, 03:11 AM   #16
cleong
cleong's Avatar
You're right about decreasing torque. But you're wrong about losing speed.
A smaller tire buys you acceleration at the expense of speed. A larger tire trades acceleration for better speed.
So by using a larger tire, I would be a tad slower to get to 60mph but I can hit a higher V-max before I run out of engine revs.
TRD Blue brake pads
DC Sports header
Old 08-10-2007, 03:22 AM   #17
fu_im_from_texas
Drives: Liftback
+1
+1 ... think of it this way... we have more torque to the wheels in 1st gear, but we have a higher top speed in 5th ... larger tires raise the over all gear ratio
Pavel Olavich was probably assuming that the top speed is drag limited... which doesnt seem to be the case...
Old 08-07-2007, 11:48 PM   #18
ArBoY
Drives: Yaris Hatch 07
Once I did with stock tires (14") and 5 persons on the inside... 120 mph
And now that I upgraded my wheels to 17" I´ll try and post it!!!
<a href=http://img247.imageshack.us/my.php?image=yarisft5.jpg target=_blank>[img=http://img247.imageshack.us/img247/9080/yarisft5.th.jpg]</a>
http://jailbaitgallery.com
ArBoY is offline   Reply With Quote
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 10:18 PM
Yaris Crashed! elsteverino889 General Yaris / Vitz Discussion 13 11-06-2006 03:59 AM
