08-13-2007, 02:06 PM
#11
Drives: 07 Yaris, 4dr Daily Driver
Originally Posted by ChinoCharles
OK, so I know you guys are wondering where the fuck the dyno results are.
Sunday rolls around and I pop open the install DIY and see that I need a 3/4 inch drive ratchet. Well, I decide I am going to try and torque those bolts off with a 1/2 inch drive, because I had honestly never seen a 3/4 inch ratchet and wasn't convinced I could easily find one. Took the heat shield off, got the car up on stands, and crawl under there... not happening. Chris wasn't kidding. You need some serious leverage for those collector bolts, as they are torqued to 32 lb/ft. Well, I go out and find a 3/4 inch drive ratchet at Autozone (surprisingly) but they don't sell any adapters or sockets for it. I then tried Sears hardware, regular Sears, Advanced Autoparts, Lowes, and Home Depot. Nothing. Called the dyno shop to see if he had one sitting around, and that was a big fat no. I was shit outta luck. So, I ordered a 3/4 inch female to 1/2 inch male adapter from Amazon.com and upon reception of that (should be here soon after Christmas) I will install the new header and go to the dyno shop.
Sorry for the teaser... of course the one tool I need seems to be a tool that you can't get without dropping thousands on a master mechanic's toolbox. God dammit. I'll update when I get the adapter and get the new header on. Sorry guys!
On the bright side, I now have a ratchet big enough to kill a large individual.
Chinocharles how much was the 3/4 to 1/2 connector piece?...I'm having the same problem getting the bolt off the bracket...all the other bolts came off easy but there's no room in the damn compartment to move the ratchet and hold the wrench to the nut on the other side of the bracket...plz help another noob mechanic.
Reason: changed bolt to nut
