Old 01-09-2010, 10:54 AM   #1
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
didn't know this thread was here. cansf ambient air works on us 2010 yaris 5 door hb
127.0.0.1 is offline   Reply With Quote
Old 03-14-2010, 12:23 PM   #2
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
I've changed one of my Scanguage spots to read out TPS. How come the max is 81 (have seen 82). Is this accurate that the butterfly valve is only opening 81%, not that I think I'm missing out on some performance, but curious if by design there's no reason for it to open to 100% - or - the reading is not accurate.
FYI - I've never used a Scanguage in any other car
BuildCode is offline   Reply With Quote
Old 03-14-2010, 05:54 PM   #3
Rick
Drives: '08 Yaris LB 5M
If Toyota's firmware design is similar to Ford's (I'm guessing it is) then it's not inaccurate and also not a direct indication of throttle position. To avoid needing precision calibrated throttle position sensors ($$$), they use a % of possible measurement range. The firmware learns what % indicates closed throttle and what % indicates WOT. Individual TPS sensors don't have to be 'exactly' like each other and that makes them much cheaper to produce.
It also means that as the TPS changes slightly over the life of the component it creates no problem. The firmware adjusts for the changes.
In the Ford world 0 volts = 0% and 5 volts = 100%. The Ford TPS output doesn't go down to 0v and doesn't go up to 5v. I see 21% to 92% on my Cobra.
There is a 'normalized to 100%' proprietary extended parameter but Scangauge doesn't use it.
Rick is offline   Reply With Quote
Old 03-14-2010, 07:44 PM   #4
BuildCode
BuildCode's Avatar
cool! that's good to know, thanks for the detailed response
Old 07-03-2010, 04:56 PM   #5
Billiam
Drives: '10 White Yaris 4D LB
Anyone tried this vent mount with their Scangauge?
http://cgi.ebay.com/Car-Air-Vent-Mou...item5190dfc8a3
If you want to enjoy your car, stay off of the internet.
Old 07-04-2010, 04:16 AM   #6
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Didnt a vent mount clip come with the device?or maybe it was some other electronic gizmo,what ever it was it didnt work very well, I found a bit of velcro
was the easiest and most versatile way to mount the gauge on the dash just in front of the steering column.
Old 07-04-2010, 10:49 AM   #7
Billiam
I haven't ordered mine yet, but I don't think it comes with any mounts (maybe velcro). Anyway, I saw the windshield mount and this "vent" mount on ebay. Just wondering if someone had actual experience with this mount and Scangauge together. Our out-board vents are kinda weird, so I can see it not working too well. But if it does, it's a better solution than velcro, IMO.
Old 08-12-2010, 06:26 PM   #8
kazama82
Drives: VIOS
i notice that my odo meter is not the same as scangauge odo meter..scangauge shows faster increment compare to my car odo..anyone notice this?..for example now my car odometer at 90km, but my scangauge odo already showing 96km..
kazama82 is offline   Reply With Quote
Old 02-22-2011, 11:18 AM   #9
bkndacn
bkndacn's Avatar
Drives: 2009 Toyota Yaris
So I just bought my Scangauge II from Garm and I've had it in my car for about 3-5 days now .....
On the first day that I had it in the car I drove down to DC (about 120 miles one way) as I do every friday night (work) and my scangauge told me I averaged 45 mpg for the whole trip (95% HWY 5% CITY) and then on the way back I averaged 43 (prob bc CC was on)
But looking at everyon elses #s I feel like thats too high!! lol and Ideas as to what might be causing this false readout? if in fact it is a false maybe i just have a super FE Yaris!
I got a ride in Garms' Yaris and got on a plane within 24 hours of each other.... his yaris was faster! I bet if he put wings on it he could get passed all that L.A. traffic!
bkndacn is offline   Reply With Quote
Old 02-22-2011, 02:36 PM   #10
jambo101
jambo101's Avatar
Dont you have to set a standard on the device by recording your first full tank of gas then inputting some parameters on your second tank of gas??
Old 02-22-2011, 02:58 PM   #11
bkndacn
bkndacn's Avatar
yeah but it still tells me what my average MPGs are
Old 02-24-2011, 03:02 AM   #12
jambo101
jambo101's Avatar
Is that the setting where the mpg reading is all over the place or the X gauge reading that posts average mpg by the day,the trip or the tank.?
Old 02-22-2011, 07:47 PM   #13
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Hey guys, just got mine today works pretty well!!
I've got a few questions:
Anyone have experienced issues by placing it over the steering wheel because of the direct sunlight it may get there?
Is there any way I can read whenever the a/c compressor clutch is engaged?
Is it true that I can send codes into the ECU, like turning on/off the radiator fan for example?
http://www.verboom.net/info/speedste...16/xgauge.html
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 02-24-2011, 02:23 PM   #14
Kitt
Kitt's Avatar
soo what is your average water temp and idle rpm??
Old 04-18-2011, 04:35 AM   #15
jambo101
jambo101's Avatar
My water temp stays around 184-188
Idle RPM 710
Old 04-28-2011, 07:09 PM   #16
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
* crossposting to this official thread =)
Finally decided to get one and I think it's great -- note the current units on display are in metric:
The gauges I use for now are:
• 7.4 L/100KM = 31.7 MPG (Ave Fuel Economy per tank)
• 421 KM = 261 Miles (Distance to Empty tank)
• 13'C = 55.4'F (outside ambient temperature)
• 789 RPM idle <-> Switches to Instantaneous MPG
* Edit: By the way, this is how I mounted the SC II against the windshield.
Material is plexi-glass from left over projects -- pretty strong/sturdy and does not move at all. Total cost = $0
* View from backseat
Old 05-15-2013, 06:51 PM   #17
nookandcrannycar
Those 3M Dual-Lock fasteners are fantastic. I've been using them for probably close to 10 years for various car related and other uses.
Old 02-25-2011, 06:04 PM   #18
Kitt
Kitt's Avatar
Has anyone been able to add the air to fuel ratio gauge on xgauge?
