Old 09-24-2007, 10:41 AM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Originally Posted by staticorex View Post
:) You got them on?
No, not yet. I've got to get the fronts done today after I get the wrenches.
Old 09-25-2007, 10:25 AM   #2
Thirty-Nine
I'm having some issues with the front sturts.
We've put everything back to gether on the struts and are using the supplied bumpstop vs. the OEM one. Everything is put together in this order:
shock
Megan bumpstop
Megan dustboot
Megan red anodied metal top with plastic noise reducer
OEM upper coil spring seat
Strut mounting bearing
OEM nut
OEM strut support sub-assembly
This assembly gets attached to the steering knuckle and swaybar, and put up into the shock mount hole. On top of that goes the suspension support, then the Megan lock nut.
When I lowered the car down, both shocks rose up about 2" from each shock tower hole. Something is obviously not right, and I can't for the life of me figure it out, but something is definately not right.
I did NOT use the metal spacers that go onto the shock piston (they come assembled with these).
My only thoughts are: 1) The nut on top of the strut mounting bearing isn't all the way down or 2) something else
ANY help would be greatly appreciated.
Old 09-25-2007, 10:32 AM   #3
03Z33
03Z33's Avatar
Drives: TCR10
You're re-using the stock upper rubber piece right? I think that is what you call the "OEM upper coil spring seat"?
Most aftermarket shocks for this car will stick out further on top, that's normal. If you can post a pic of it, that would be helpfull so we can try to see if it's supposed to be that way.
03Z33 is offline   Reply With Quote
Old 09-25-2007, 10:48 AM   #4
Thirty-Nine
These sick up so that the top cover is up in the ari, which isn't right, which makes me wonder if the bolt that goes on the strut moutn isn't tightend all the way down. I did use this:
The problem is the circled part (and the bolts) rise up about 1.5 inches when lowered down:
Obviously that isn't supposed to be up in the air.
I can't get photos until tonight after work and hopefully, I'll be able to trouble shoot this this today so I can finish it tonight.
Old 09-25-2007, 10:54 AM   #5
03Z33
03Z33's Avatar
Drives: TCR10
You've got it right then. That's actually completely normal. Mine sticks out atleast that much and so does everyone elses that has installed Tanabe springs or Cusco coilovers. That's just how it is.
I'm searching for a pic right now...
Here's a quick one from Chris07LB's Tanabe Strut bar how to:
It's difficult to see in this pic, but there is a gap there. I'd take a pic of mine to show you, but my car isn't back from the body shop yet.
Old 09-25-2007, 11:09 AM   #6
Thirty-Nine
I don't think I explained it well.
The support, which I circled in the diagram above, is NOT in the strut-tower hole. It is raised above the strut tower about 1.5", and makes NO contact with the metal below. This means that the strut can wiggle around in that hole because there's no support.
Old 09-25-2007, 11:13 AM   #7
03Z33
03Z33's Avatar
Drives: TCR10
Yes, I completely understand and that is completely normal. That support doesn't center the strut in the housing, the strut is centered by the lower rubber support from underneath. The upper "support" that is sticking out is only used to keep the strut from pulling out of the car when the car is raised in the air. Hopefully someone else with coilovers who has access to the car will take a pic?
Old 09-25-2007, 11:16 AM   #8
Thirty-Nine
If that's the case, it renders the adjuster knobs useless... BRB; I'm making an MS Paint version of the pic!
Old 09-25-2007, 11:23 AM   #9
03Z33
03Z33's Avatar
Drives: TCR10
For the adjuster, a few coilover companies such as Zeal and JIC sell a flexible extension line which will hang forward to where it's easier to reach and still be able to turn the adjuster. Just search for it for cars like the 350Z rear suspension where they have the same problem. A simple version of this would be to weld or attach a flex-extension from a 1/4" or 3/8" socket set to the top of the adjuster and have it stick out to where you can reach.
You can see the two black flexible adjuster lines between the two coilovers in this pic:
Or you could just drill a small hole directly above the adjuster and just stick a tool in there when you need to adjust
Old 09-25-2007, 11:32 AM   #10
Thirty-Nine
Okay, so here's what it looks like (as you can tell I'm no artist. The two nuts are the same size, BTW (don't say that every day)):
Old 09-25-2007, 11:37 AM   #11
03Z33
03Z33's Avatar
Drives: TCR10
Yes, that would be normal. That is how it will look after installing the coilovers or aftermarket springs. I realize this doesn't "look" normal but it is
Old 09-25-2007, 11:46 AM   #12
Thirty-Nine
So that's normal? Weird. That means I took the whole damn driver's side off for nothing! LOL
I cut the dampner adjuster rods down so they don't hit the top of the wiper cowl. I guess I'll take 'em down a bit more after this.
Old 09-25-2007, 02:39 PM   #13
Thirty-Nine
Okay, so I called Megan, and I think I screwed something up. I'm using the Megan coil seat AND the OEM coil seat. A guy at Megan said there shouldn't be any metal-on-metal contact.
EDIT: That should read: Red anodized part + OEM spring seat = no?
Old 09-25-2007, 05:27 PM   #14
03Z33
03Z33's Avatar
Drives: TCR10
Isn't the OEM spring seat rubber? How would that red aluminum spring seat mate to the underside of the car? On the SK coilovers there was a similar aluminum spring seat but it required the use of the stock upper rubber spring seat.
Old 09-25-2007, 06:18 PM   #15
Thirty-Nine
The OEM unit is metal; the OEM dust boot has a built-in rubber grommit that seats between it and the top of the spring.
The red aluminum ring apparently mounts to the large rubber "sub assembly," which is part of the OEM unit as shown in the OEM diagrams.
There are also some 1.5" metal spacers that came on the shock's pistons (they sit just below the threads on the top end of the shock's pistons), and I'm not sure if I should use them or not. I did not install them on the rears.
I'll tell you this: Megan does NOT include a real set of directions with these, and the folks at Megan Racing weren't able to help much either.
Old 09-25-2007, 06:25 PM   #16
RShatchback
Drives: 07 yaris liftback
Everytime i see a new post in here - i keep hearing the word. Tein... echoing in the back of my head. Good luck with the issues - hope you get it worked out...
Car forums are kinda like the public library - somepeople are just checking stuff out, and plenty of other people are just telling stories...
RShatchback is offline   Reply With Quote
Old 09-25-2007, 06:37 PM   #17
Thirty-Nine
Really -- I don't think these are any more difficult to install than the Teins. The issue is that Megan doesn't give you a list of what needs to be reused from the OEM suspension. With this, things would've been MUCH smoother. Instead, you've got to figure it out on your own.
If you want a softer ride without adjustability, then by all means, go Tein Basics. However, those of us who want adjustability (and don't have $1,300+ to spend on a set of coilovers), Megan may be a good choice. I'll let you know if I ever get them installed ...
Old 09-25-2007, 06:47 PM   #18
cdmyaris
cdmyaris's Avatar
Drives: 07 Yaris Liftback
should have pmed wesellcarpart or c2auto. They sell tein coilover set near $880
Toyota Yaris FTFW!!
cdmyaris is offline   Reply With Quote
Megan Springs? churp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 06-06-2007 03:11 PM
Megan or Tein suspension elmercurrie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 05-31-2007 09:41 PM
Comp S Coilovers for a discount and installed BulletProofAuto California 1 05-12-2007 01:04 AM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 04:43 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
