Old 09-27-2007, 05:11 PM   #1
kapo
Argentina Presente!
Drives: 07 White LB
thanks! good advice!
now.. one thing.. i was playing arround with my setup, and i was able to raise or lower the car using the top spring perch... is possible if you can measure between the spring stop and the bottom stop? so i can put it at stock distance..
thanks!
kapo is offline   Reply With Quote
Old 09-27-2007, 08:40 PM   #2
dsc_pat
track or die
Drives: Yaris LB CE CDM
thanks for all the info
asked if you had done mechanic before only to compare to myself..thanks !
let us know how stiff it is and how low you drop the car...can you go as high at stock height ? (or almost stock..) ?
dsc_pat is offline   Reply With Quote
Old 09-27-2007, 10:12 PM   #3
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Here's a pic of the Megans w/my Rays Engineering Texan Shot Guns (16x7 +37 205-50-16).
I need to either raise the rears or lower the fronts a bit, I think. Rubs a bit under cornering. I will say, with these sticky Yokohama ES100s, this thing is like it's on rails.
Old 09-28-2007, 12:07 AM   #4
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
looks great on those wheels with that drop
SPONSORED BY
Old 09-28-2007, 03:00 AM   #5
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
yay another yaris with an aggressive stance ^^
Old 09-28-2007, 10:11 AM   #6
03Z33
03Z33's Avatar
Drives: TCR10
Looking good! Glad you got it worked out in the end. Just sorry I couldn't give you more definitive advice... I must have assumed you had the strut bearing installed already.
03Z33 is offline   Reply With Quote
Old 09-28-2007, 11:38 AM   #7
Astroman
Modded Moderator
Astroman's Avatar
Looks good! I hate my wheel gap
Old 09-28-2007, 12:31 PM   #8
kapo
Argentina Presente!
Drives: 07 White LB
looks good!!!
Old 09-28-2007, 12:47 PM   #9
smokinyaris
smokinyaris's Avatar
Drives: bad boy
THAT SHIT IS ILL SON
smokinyaris is offline   Reply With Quote
Old 09-28-2007, 11:59 PM   #10
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
I use Megan coilovers and like them. I'm running them full hard in the front and mid in the rear. The 6k springs are pretty stiff in the back but good enough for the street and weekend track runs.
I plan on getting the front springs changed from the 5kg to 7kg for the track, but this will make it harder on the highway where the car bounces all over the place going into the mountains.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 09-29-2007, 02:38 PM   #11
Thirty-Nine
I haven't yet cranked the dampening up yet. I'm still on full soft and it's still very stiff. I want to crank 'em up to full stiff just to see what it's like.
Old 10-20-2008, 01:34 PM   #12
ToTo
ToTo's Avatar
Drives: Toyota Yaris T SPORT
Looks really good, but lower the front a bit!
ToTo is offline   Reply With Quote
Old 10-20-2008, 04:19 PM   #13
Thirty-Nine
If I go any lower in the front, I'll rub like crazy. As it is now, I rub a bit in front with 195/55/15 tires and 15x6.5 (+40) wheels.
It's been over a year now, and I still really like them -- no problems.
Old 10-30-2008, 06:51 AM   #14
ToTo
ToTo's Avatar
Does anyone know how low can you go on coilovers without rubbing on 195/50/15?
Old 11-08-2008, 07:20 PM   #15
seth_man
seth_man's Avatar
Drives: 08 Liftback
pretty low, ive got 205/45/16 tires 16x7 +40 wheels and i dont rub. i cant fit a finger between the fenders and the tires. lots of preload though.
seth_man is offline   Reply With Quote
Old 10-30-2008, 02:06 PM   #16
Thirty-Nine
Pretty darn low. I'm nearly at full UP in the rear, and the fronts could go down a lot more if you're going for a show car look. It'd be miserable to drive that low, though.
Old 11-06-2008, 04:35 AM   #17
ToTo
ToTo's Avatar
Thanks for the info! It would be a miserable ride even with coilovers?
Old 11-08-2008, 04:20 PM   #18
Thirty-Nine
The Megans are pretty stiff, even at soft settings. If you're looking for a nice, soft ride with coilovers, check out the Tein Basics.
Megan Springs? churp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 06-06-2007 03:11 PM
Megan or Tein suspension elmercurrie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 05-31-2007 09:41 PM
Comp S Coilovers for a discount and installed BulletProofAuto California 1 05-12-2007 01:04 AM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 04:43 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
