Old 04-04-2009, 05:03 PM   #1
having the same problem with mine...gotta take the fronts apart tomorrow....
damn megans and their no instructions...
Old 04-06-2009, 01:47 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Did you get your problem solved?
Old 04-06-2009, 07:23 PM   #3
sorta..might have been using the wrong bolt at the top of the bearing
also lowered the height in the front another 1/2". still sits a bit too high above the strut top, but ill live with it, i guess
Old 11-01-2009, 08:59 PM   #4
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
Silly question but how do you adjust the height for the rear? Is it the spring or the damper?
weedtank is offline   Reply With Quote
Old 11-01-2009, 10:00 PM   #5
perch for the spring for height
Old 01-27-2010, 11:46 PM   #6
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I'm resurrecting this thread in hopes that 39 might post that DIY/pics he promised?? :)
If nothing else, how did you go about pressing-out the strut bearings? There is a lot of great info about these coilovers in this thread, it just takes a while to find it.
Any chance you can post some dimensions/settings for your current setup? Like, how much rear shock thread is showing? How much preload did you end-up going with? How low did you drop it without lots of rubbing?
Thanks! the thread alone has been mucho helpful.
Old 01-28-2010, 10:07 AM   #7
Old 01-28-2010, 12:24 PM   #8
ozmdd
ozmdd's Avatar
Thanks. A picture really is worth a thousand words!
Old 03-01-2010, 06:50 AM   #9
ToTo
ToTo's Avatar
Drives: Toyota Yaris T SPORT
Hey guys! Im really trying to understand this install, but can someone give me some info on the rear shock to begin with? I dont quite understand the purpose of the threads on the bottom of the rear shock? What is it used for and how do I adjust it?
Thanks!
ToTo is offline   Reply With Quote
Old 09-25-2007, 11:15 PM   #10
03Z33
03Z33's Avatar
Drives: TCR10
That looks correct, all three suspensions I installed on my car left the gap like you have. I never measured it, but with the Cuscos I remember it being at least that high, it still looks very similar with my current setup. I'll do my best to take a pic this week when I swing by the body shop.
Old 09-25-2007, 11:45 PM   #11
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Tein fits near flush, nothing like pictured
SPONSORED BY
Old 09-25-2007, 11:49 PM   #12
dsc_pat
track or die
Drives: Yaris LB CE CDM
but tein uses OEM hats (almost all «top» OEM hardware ?) ? and the megan/ksport (i think we can say that...) uses it's own top plates...
dsc_pat is offline   Reply With Quote
Old 09-26-2007, 01:04 AM   #13
03Z33
03Z33's Avatar
Drives: TCR10
If I remember how it works correctly, the only thing that will affect the height of the dust cap is the length of the portion of the shaft the sticks out on top of the upper strut mount and the length of the threaded portion on the shaft. It really makes no difference to the functionality of the suspension. If the manufacturer wanted to make it look more like OEM then they would either source a slightly shorter strut or thread the strut further down so that the dust cap can be lowered more. The fact is that there are only so many struts to choose from in the aftermarket and it probably doesn't make sense to custom make a specific shock length for each and every car.
Megan Springs? churp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 06-06-2007 03:11 PM
Megan or Tein suspension elmercurrie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 05-31-2007 09:41 PM
Comp S Coilovers for a discount and installed BulletProofAuto California 1 05-12-2007 01:04 AM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 04:43 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
