Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Although every change I've made added to my MPG numbers by far and away the largest item was FAS. If the engine isn't running it isn't using fuel. That's as MPG-friendly as it gets.
To give you an example of how FAS works for me let me tell you how I drive home through my neighborhood. Keep in mind that the higher tire pressures I run really help with decreasing rolling resistance, so I can coast much farther without losing much speed than someone running their tires at 32 PSI. I've already been FAS'ing long before my exit from the highway, so when I get to the bottom of the off-ramp I brake at the light, which is usually red. I wait for the traffic to pass and once I see an opening I start the engine and lightly accelerate to the speed limit of 45 MPH, unless the next light a short distance away is red in which case I only accelerate to 10 MPH and then FAS again. Once I reach 45 MPH I FAS and coast the next 3/8 mile to the turn onto the avenue that goes to my subdivision, and continue the FAS through my left turn onto that road. Once I'm on the avenue I can see that shitty light at the Starbucks/Home Depot complex, and if it's red I just keep coasting at like 10 MPH while I time the green. Once it's getting close to green, or of it was green to begin with, I start the engine back up and lightly accelerate to 35 MPH, then FAS the next 3/8 mile to a stop sign. As I brake at the stop sign I start the engine up just as it's my turn to traverse the 3-way intersection, then accelerate back up to 45 MPH again. From this point I go into my last FAS for a total of a 1/2 mile that goes to my entrance road into my subdivision, then has an immediate left, then a right 100m later, then 100m to my house, finished by a left turn and a 7-9 MPH coast right up the driveway and into my garage (the trick is to start the garage door opening from a ways back). The total distance driven in this scenario is about 1.5 miles containing moderate traffic, 3 lights and a stop sign, but my engine was only turned on for about 3/8 mile of it despite me keeping up decently with the traffic patterns.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
Modded Moderator
Doesn't all that shorten the life of your starter though?
That it does, but a new starter - which I can install myself - costs about $40. FAS'ing saves me more than that in fuel costs each month.
I don't expect it to be much of a problem in the future, though. Most starters used by Toyota are good for around 17,000 uses, which should last me about 3 or 4 years. I'm still on the stock starter and it's 7 months old now
#4 | |
Small Car Lover
Wow that's intense! Isn't there concern for safety? Like what if you have to suddenly accelerate or whatever? Also in some situations you have to accelerate hard for "safety" reasons meaning to get out of the way or get in a lane, knnow what I mean? Even if your going on the on-ramp for the highway you have to accelerate even faster than gradual sometimes for "safety" of you and others so they don't rear-end you or have to slow way down and almost rear end you. Also, how do you deal with rush hour driving like that and impatient people? Tailgaters? I hate rush hour cause well, its rush hour and it kills my mileage! And I know that's for any car. Sure there are techniques but still. I'm NOT bashing you or putting you down, just curious how you deal with it. Mileage is important to me as well but I'm not as cautious as you are. But keep up the good work mileage king! ![]() ![]()
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
#5 | ||||
No worries at all, ECHOKnight2000. I'm always happy to discuss these things.
![]() Quote:
As long as I am doing the speed limit, or close to it, by the time we reach the merge point we're all perfectly OK. If someone behind me is unhappy about that they'll just have to get over it. If they rear-end me they are automatically at fault in my State, and I get some free work done on the Yaris. I am not here to help other people waste fuel and create extra emissions by aiding them in their aggressive driving.Quote:
Tailgaters are usually not a problem for me as I live in the right-hand lane but they sure are an odd breed as they do things that make no sense at all. They tailgate me even in the right lane whether I'm doing 10 over the limit, the limit, or 10 under the limit. As such I've learned to just ignore them for the most part, but if I get one on me that's really aggressive about it I simply take my foot off the throttle and gradually slow down to about half the speed limit. That gets them to change lanes every time. I also get the occasional tailgater on Mount Rose which is a very dangerous and intensive 2-lane highway, meaning only 1 lane in each direction. The speed limit on the mountain is 50 MPH and that's exactly what I do both up it and down it. Some folks like to think of this highway as a race track and are most unhappy with doing the speed limit but that's a problem between them and the Nevada Department of Transportation as far as I'm concerned. As such I never take it personal and I never pull out in the "slow vehicle turnouts" because I'm not going slow... I'm going the speed limit. It's a different way of looking at and interacting with the world. Much safer, much saner, much more efficient and much more logical. Just in case you're wondering, yes, I do get flipped off about once per month, and it's always by someone who is driving so aggressively that if a Police Officer were present they would go right past a citation to getting arrested and having their vehicle impounded. I also get the occasional glare, but we all get that. hehe Window tint helps a bit with the evil eye types. What's funny is once you become this attentive you begin to realize just how bad most other people actually drive. There's not a week that goes by where I don't see something that makes me drop my jaw and gasp in astonishment at the sheer stupidity and poor decision making. It would be funny if these people weren't putting us all in danger every time they get on the road.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. Last edited by BailOut; 09-12-2007 at 12:14 AM. Reason: Typos |
Small Car Lover
BailOut, THanks for the explainations! With the acceleration on the ramp, I too just gradually accelerate as there is no need to floor it. But that's because there is little to no traffic but when traffic is a little heavier I have to accelerate to merge or even if I'm getting off one highway to the next (think clover leaf). Especially if a big truck is barreling down and since I have to slow down going around a curve let alone the clover leaf I have to floor it to get back up to speed when I get to the highway that was under the one I got off on, so I don't get crushed. So do you experience that? I totally agree with you in observing the driving, even I do it too (observe) and sometimes appauled at what some people do. In fact not long ago when I drove up to the north western part of Minnesota the speed limit out of the city was 70 but I went 65...until my mom (which I was following) was going 80 if not more cause we were late for something which sucked not only my gas and money but just you know...hurt. Then on the way back I was so uncomfterable with my sister driving as she is not MPG conscience like I am so I was upright and concerned the whole time. I should have took over but...I don't know! But knock on wood according to my scanguage I got 47mpg which I've done better and could have done better that time but oh well!
Oh even if you are taking it easy sort to say, in rush hour there are some moments you have to slam on your brakes, tell me you come accross that, well even generally just for safety reasons. I know you are aware but you can only do so much...and plus people might cut in front of you and what not or the light will change and you realize you don't have time so you put the breakes on or the person in front of you puts the breaks on. And I know braking hard kills mileage so...but thanks for the explainations. I'll take what you said in consideration.
#7 | ||
I did have to stand on my brakes once last Winter, though, on Mount Rose. A tourist in an inappropriate vehicle (read that as a RWD rental SUV) lost control around a sharp and icy corner as they came downhill, and they were careening off the inside snowbank and outer guardrail like a pinball. They were completely out of control and their movement was so erratic that it was impossible to judge what the safest thing to do was so I just moved as far right against the snowbank as I could and then stopped as quickly as possible in order to eliminate my kinetic input in case we would collide. Luckily they missed me by a good margin and I was able to continue on my way unscathed. Even then, though, because I was paying attention I had more time than I needed in order to come to a decision and implement it. I was in position and stopped from 35 MPH and just watching this fellow for a good 4 seconds before he passed me. The same held true when my driver's door got hit this Summer. I didn't have enough time or space to fully get out of that guy's way after he failed to give me the right of way so I made a calculation and stopped where I thought he would only hit my door rather than scraping down the entire side of the car. It worked. My door got creamed but the damage was isolated only to the door. I saw him so early on that I had more than a full second to just sit there and simply watch him coming to hit me. heh
#8 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
The merging part is a lot harder in the GTA, because of the huge volume, but I find the best way to merge is to put my signal on a while before the solid line turns dashed and gradually start hedging towards the left side of the lane. Usually people will slow down or get out of the merging lane, because most people here are going to merge whether there is space or not and usually without signalling. Signalling seems to be a lost art around here. You can never signal too early or too much. I think the whole key is to become confident in your ability to control traffic as much as possible. For example, one trick I use to feel less pressure from bad drivers about going a reasonable speed is to find a transport truck going 90-100km/h and follow them but stay well back to avoid rocks etc. I find people will usually not cut you off if they have to change lanes in a few seconds again to pass a transport, plus I'm also supplying merging drivers with a huge corridor where they see they can safely accelerate into. |
