Small Car Lover
BailOut, THanks for the explainations! With the acceleration on the ramp, I too just gradually accelerate as there is no need to floor it. But that's because there is little to no traffic but when traffic is a little heavier I have to accelerate to merge or even if I'm getting off one highway to the next (think clover leaf). Especially if a big truck is barreling down and since I have to slow down going around a curve let alone the clover leaf I have to floor it to get back up to speed when I get to the highway that was under the one I got off on, so I don't get crushed. So do you experience that? I totally agree with you in observing the driving, even I do it too (observe) and sometimes appauled at what some people do. In fact not long ago when I drove up to the north western part of Minnesota the speed limit out of the city was 70 but I went 65...until my mom (which I was following) was going 80 if not more cause we were late for something which sucked not only my gas and money but just you know...hurt. Then on the way back I was so uncomfterable with my sister driving as she is not MPG conscience like I am so I was upright and concerned the whole time. I should have took over but...I don't know! But knock on wood according to my scanguage I got 47mpg which I've done better and could have done better that time but oh well!
Oh even if you are taking it easy sort to say, in rush hour there are some moments you have to slam on your brakes, tell me you come accross that, well even generally just for safety reasons. I know you are aware but you can only do so much...and plus people might cut in front of you and what not or the light will change and you realize you don't have time so you put the breakes on or the person in front of you puts the breaks on. And I know braking hard kills mileage so...but thanks for the explainations. I'll take what you said in consideration.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
#2 | ||
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I did have to stand on my brakes once last Winter, though, on Mount Rose. A tourist in an inappropriate vehicle (read that as a RWD rental SUV) lost control around a sharp and icy corner as they came downhill, and they were careening off the inside snowbank and outer guardrail like a pinball. They were completely out of control and their movement was so erratic that it was impossible to judge what the safest thing to do was so I just moved as far right against the snowbank as I could and then stopped as quickly as possible in order to eliminate my kinetic input in case we would collide. Luckily they missed me by a good margin and I was able to continue on my way unscathed. Even then, though, because I was paying attention I had more time than I needed in order to come to a decision and implement it. I was in position and stopped from 35 MPH and just watching this fellow for a good 4 seconds before he passed me. The same held true when my driver's door got hit this Summer. I didn't have enough time or space to fully get out of that guy's way after he failed to give me the right of way so I made a calculation and stopped where I thought he would only hit my door rather than scraping down the entire side of the car. It worked. My door got creamed but the damage was isolated only to the door. I saw him so early on that I had more than a full second to just sit there and simply watch him coming to hit me. heh
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#3 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
The merging part is a lot harder in the GTA, because of the huge volume, but I find the best way to merge is to put my signal on a while before the solid line turns dashed and gradually start hedging towards the left side of the lane. Usually people will slow down or get out of the merging lane, because most people here are going to merge whether there is space or not and usually without signalling. Signalling seems to be a lost art around here. You can never signal too early or too much. I think the whole key is to become confident in your ability to control traffic as much as possible. For example, one trick I use to feel less pressure from bad drivers about going a reasonable speed is to find a transport truck going 90-100km/h and follow them but stay well back to avoid rocks etc. I find people will usually not cut you off if they have to change lanes in a few seconds again to pass a transport, plus I'm also supplying merging drivers with a huge corridor where they see they can safely accelerate into. |
