Old 09-15-2007, 10:22 PM   #1
caveatipse
Drives: 2007 Black Yaris
Just because you don't believe it doesn't mean it isn't so. Please think twice and ensure you are knowledgeable on the subject at hand before the next time you give advice.
And just because you believe it does not make it so. Why don't we both do some more scientific research and then share our findings? I certainly could be wrong, but I have read that before. I will check again.
caveatipse is offline   Reply With Quote
Old 09-16-2007, 02:01 AM   #2
BailOut
Steals terrorist's lunch
BailOut's Avatar
The day you top my 52.5 MPG record we will talk.
- Brian
Share the Road
Old 09-16-2007, 02:42 AM   #3
caveatipse
But I am not talking about gas mileage. I would imagine that, yes, gas mileage is better if you turn your engine off every time you stop. I was actually talking about wear and tear on the engine and the starter. I contend that wear and tear is greater if you are constantly turning your engine off then back on.
Old 09-16-2007, 08:08 AM   #4
xpeteyjtx
Drives: 07 BB Yaris
Yea, wear and tear is greater. But... the wear and tear might be minuscule since the engine is already warm and well lubed (in comparison to a cold start). If you want the engine to last 150,000 miles, my guess is that shutting it off/turning it on at a red light won't make a difference. But by 250,000 miles, it may start to consume some oil. Obviously, I'm making these numbers up, but you get what I'm saying.
If you do shut it off/turn it on, the starter is being worked more. It would be interesting if Toyota released cycle ratings on their starters. That could give us an idea of how long they would last.
That being said, I personally don't shut the engine off. I don't idle too long at red lights since they seem to change quickly, so it's not really worth it to me.
If someone was up for it, they could do a little experiment with UOAs (used oil analysis). They could do a few samples with the shutting the engine off technique and then do a few with leaving it on. Obviously, constants such as oil brand/weight and change interval must be kept constant, along with driving style. Also, it would be best if the engine had more than 30,000 miles, so that the numbers shown on the UOAs are normalized
xpeteyjtx is offline   Reply With Quote
Old 09-17-2007, 08:39 AM   #5
voodoo22
Drives: Yaris Sedan (auto)
Thanks for the thoughts. Hopefully someone with a scanguage on an auto can test this one day.
I personally don't believe shifting to N at a stop can make much of a difference, because Toyota knows 99.9% of people won't do this and I'm sure they taken measures appropriate to that knowledge. I just don't want to do it, if it's causing more problems than good.
I never coast in N, when I am coasting in heavy traffic or approaching a red light, I will shift from D to 3 if I'm going under 80 km/h to try and save the brakes and improve the chances of benefitting from DFCO.
I also shut off the car when I'm at a long light and I do pay attention to the other lights so I don't inconvenience all the IMPORTANT people who have to tailgate and don't have time to use signals while they speed up to the next red light or slow spot of traffic
So far I've been doing very well on gas, but the cold weather is coming and I can feel the FE slipping away!!
voodoo22 is offline   Reply With Quote
Auto Windows (all of them auto)? SDsurfrider DIY / Maintenance / Service 7 04-13-2010 08:42 PM
Yaris Auto Transmission shifting g man Canada 9 08-23-2007 12:16 PM
Auto tranny shifting issues? Vervepipes DIY / Maintenance / Service 12 03-30-2007 08:38 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
Auto Shifting knob ? Boo General Yaris / Vitz Discussion 8 07-24-2006 07:21 PM
