Old 09-28-2007, 08:12 PM   #11
SDsurfrider
SDsurfrider's Avatar
Drives: 07 Sedan S
91 is less volatile than 87.
“Pinging” or engine “knocking” comes from pre ignition of the fuel (igniting before the spark) due to high pressures in the combustion chamber. This is why they recommend stepping up the octane if you experience pinging. Similar reasoning for higher performance engines; they are running higher pressures in the combustion chamber. So they have a need for higher octane requirement.
That is why 87 is more energy efficient because you get the same bang for less energy put into the system.
SDsurfrider is offline   Reply With Quote
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 01:29 AM
Dash rattle TSB needed ! tsportman DIY / Maintenance / Service 15 07-06-2009 07:20 PM
Rattle in head liner gonzo452001 DIY / Maintenance / Service 8 09-08-2007 03:25 AM
Front Wheel Bearing Failure craigq DIY / Maintenance / Service 4 08-17-2007 08:26 AM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 09:39 PM
