#1 | |
My favorite post:
- Cabin filters are under $20 at Kragen. - 2008 Yaris uses the same high-beam bulbs as a 2008 Prius - The rear wheels don't need alignments- just the front. and stock suspension isn't very adjustable anyway. - Half a quart of Marvel Mystery Oil can be added to a full crank case - With concerns of a hydroplaning incident I've moved up to 50k mile 185/65/15 from Firestone (meant for a Prius in wet weather) with no problems... w/ regular hard driving and no rubbing on bounces with max turn. I checked ;) - With the seat folded down flat the car sleeps 4 midgets sideways in the back. 3 in sleeping bags and 2 if you can't find the fitted kind in their size - The cigarette lighter won't work with the key in OFF - I'm about the add a police horn to a buttin next to the emergency light switch. - LED day time running headlights can be mounted in the fog light cups without removing them. But you still have to figure out wiring lol - I have cheap pop off hubcaps that stick out from the tires. I use silver Hammered spray paint after sanding to fix the scratches and it looks cooler and cooler with every coat. Some bastard better not steal them - Aftermarket window tinting looks checkered with polarized glasses on - The front windows including the little corner glass is already factory tinted a little bit. Like %8 or somthing. - It's hard to find your Yaris in a crowded parking lot and you've forgotten exactly where you parked because it was hiding behind that SUV all this time - I get 32mpg because I average 80mph and I'm fine with that - Ive run out with randoms for now |
I guess mine is special. I will have to put that in myt car description. 1.5L LB Special.
![]() ![]() Drives: 0x Yaris Hatchback Join Date: Nov 2008
I thought there was a switch in the seat - I know there is for airbags in some cars where it won't set the airbag off unless there's something like 40 pounds on the seat.
I just want to know where the crank is for the jack. Its not in the place shown in the manual unless i am blind.
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Wait, there's two filters in the air filter box? I've only seen one filter, and replace it regularly. Should I be looking for a 2nd filter as well? 80,000 adventurous miles...
![]() ![]() Drives: 2011 Base Sedan Join Date: Oct 2010
the second filter is behind the glovebox, look at page 165 of your manual, this is a cabin air filter which just makes sure clean air comes out from the a/c instead of dust and other stuff.
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
It works!!!!!! Awesome!!!!! I always hated not being able to adjust the dash brightness... I swear, adjusting it is about as clear as a super contra cheat code, but I'm glad it's there!!! Thanks Bella!
The best modification you can make is between the steering wheel and driver's seat. |
Oil is usually clear/yellow when new
A Yaris is more fun to drive when it's all paid for... as mine is.
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
Drives: 2009 Yaris YR: 3 dr hatch Join Date: Nov 2010
hey my first post here, so hi all!
Thanks heaps for the tips, i'm going to spend some quality time with my yaris right now... my tip, and i'm sure you all know this one: put your warm bottle of water or drink in the holder next to the steering wheel and put the air con on cool and angle the vents at the bottle and voila! ice cold drinks again!! |
#14 |
A Yaris equipped with TEIN basic damper coilovers delivers impeccable control! Check out my autox results here: https://axwaresystems.com/axorm/file...232009_fin.htm
http://www.youtube.com/user/ProjectYaris |
#15 |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
The Yaris steering wheel tastes of Peppermint.
Shhhh........................................... |
#16 | |
YARIS PLENTIFUL CUP HOLDERS....
The cup holders are GRAND AND SURPASS OTHER AUTOS COSTING MUCH MORE... |
#17 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
2 in front of the vents
2 in the front doors One in the rear of the center console 2 in the rear doors (on my 09 5 dr that is-not sure about the 3dr) |
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Cheers! M2
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Interesting Info on the Yaris from AU | mikeukrainetz | General Yaris / Vitz Discussion | 3 | 11-24-2006 09:18 PM |
