#1 | |
![]() Drives: Vios Join Date: Feb 2010
#2 | |
What year is your car? With the lack of the two wires on the top of the connector, it looks like yours was not factory wired for front fog lights.
Thanks for the tips CTScott. I think I have tried all the pins and it didn't worked. I will try again this weekend.
Car was made in 2008 and J model don't come with fog light installed.
OK. I don't have wiring diagrams for your area, so what I would do is to measure the voltage on each pin to ground with the headlight switch off and then with it in the parking light mode (one click). You are looking for a wire that measures 12V with the headlight switch off and then goes to 0V with it one click on.
Thanks. Will try look for it next weekend.
how much would it cost to have it done professionally!??
I've had my lights setup for almost 3 years and it's been real good to me thus far. I used the "Clowncar" method that works like a charm using my $14 OEM Toyota relay from Ebay.
I too could'nt get the lighted push button switch to work on my car, so I bought a simple black toggle switch from PepBoys Also, the bulbs that come with these kits can be garbage, the gaskets on mine would'nt even allow the bulbs to fit snugly. I bought German OSRAM brand and the've lasted thus far without replacing them. Fit tight too!
Drives: 08 yaris sedan Join Date: Mar 2011
hey i am having issue hooking up the wires on the inside for the fog ligth , i know here show step by step but my wires are different colors ,can some one help?
Are your wires white and yellow?
![]() Drives: 08' toyota yaris liftback Join Date: Jun 2010
i did this install this weekend and everything works fine except for one detail. When my headlights are on my fogs shut off, but when my headlights aren't on, my fog lights are able to turn on.
PLEASE HELP!! spent way to much time on this. |
anyone ?
#15 | |
1.5 or 2.5 both=0-60 in 8
Pin 3 and 4 go to nothing on the stalk (i.e. no pin on the stalk side). If you had an OEM stalk with the fog switch on it then it would those two pins and the fog switch would simply bridge them. Pin 3 goes to the negative side of the fog light relay and pin 4 is a headlight low beam switched ground.
Hopefully the ebay switch that you purchased is a four pin, not three pin illuminated switch, since the switching and illumination need to be separated.
#17 | |
This is what I got from Ebay: http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT It is four pin (I hope it is the right kind) . so from what I understand is that we switch pin #3 to the ground (which powers the foglights) and pin #4 powers the LED white they have a common ground? Thanks!
#18 | |
The LED needs to be connected to the illumination circuit. If you connect it to the fog light switching circuit, the LED will remain on all the time (even when the ignition is off). If you look at the attached document, which I recently put together for the MI fog light kit, it shows where to connect the LED to the connector for the lighting for the AT shift lever (the feed is present on both AT and MT cars). The green wire is + and the white is -. By using this feed for the LED, it will only light when the headlight switch is on and will dim with the other interior lights when you adjust the dimmer rheostat.
| Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 02:18 PM |
| Looking for the Toyota Fog Light install | RocknRollRon | DIY / Maintenance / Service | 33 | 06-13-2010 07:46 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
| Before I start calling around: fog light install prices | St_G | Cosmetic Modifications (Exterior/Interior) | 4 | 03-17-2007 10:45 AM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 05:24 PM |
