#1 | |
1.5 or 2.5 both=0-60 in 8
Can i get the illumination power from under the dash? as I am planing on installing the switch where you have installed yours.
#2 | |
Yarii Hunter
Drives: 2007 Yaris Liftback and S13's Join Date: May 2006
Thanks for all the great info and help, CTScott!!! I've been reading through this thread trying to decide which route I want to go, and you've saved me a bunch of questions and time.
Thanks for all the help over the years, YarisWorld!!!
![]() ![]() Drives: Yaris Hatchback 2012 SE Join Date: Aug 2011
can someone tell me the part number for the OEM fog light switch? thanks!
![]() Drives: toyota yaris Join Date: Mar 2012
Hi Im looking for the foglights to install on yaris. 2008 sedan 4 doors. Anyone knows where I can buy buy that kit thanks in advance
Check with Garm from Micro Image. He sells all kinds of Yaris extras.
Thanks for the reply. I will check!!!
![]() Drives: toyota yaris '08 liftback Join Date: Apr 2011
Hi to everyone. I purchased a Spyder OEM style foglights... I'm planning to do an install and i want to know where to connect the 12v switch wire... any suggestions on where can i tap from inside the cabin... I'm just going to connect the main power to the battery, fuse it using a separate atp fuseholder. My kit came with a relay and a separate on/off switch.
Any comments, suggestions and pics that can serve as a guide would be very much appreciated. |
![]() Drives: 08 Toyota Vios Join Date: Oct 2013
IMG_5487.JPG IMG_5493.JPG IMG_5494.JPG Hi Guyz....Sry for digging up an old post but I need some help here.... Need some insight on installing the Esuse Fog Lamp... Ive put the blue and green wire to the yellow and white wire....it does trigger the relay when my parking light is also on. then the green and black to the green wire (at the AT shifter) and to the ground... im having trouble at the A24 connector since pin 1 & 2 have already been used... i've tried the other pins and nothing seems to work... what am I doing wrong? since my lights arent working |
#10 | |
Is your Yaris a Japanese market or European market one? If you can PM me the VIN, I can check more of the details on how fogs would get installed on your car.
mine is from the thailand factory....asian market.....it's a vios.....thanx for the quick reply
pm'ed u already....thnx CTscott
OK - Got your VIN. Your car is considered a "General" area car.
From what I see there should be another connector next to the one with the green wires that is a two row connector with 12 pins. That connector would be the one where pin 1 and 2 are the fog light pins. It may be a case where the cars which come with fog lights have that connector in the harness and those that don't do not.
here's a car with fog lights in my area...the trd sportivo version....see the difference..? so IYO, do u think my DIY can be salvaged? |
I think you will need to run the feed for the lights through the firewall.
behind the relay in the cabin theres one yellow wire, two purple wires separately and two red wires in one socket...if i locate the red wire and connect the red wire from the fog light, would that suffice? i just want the fog light indicator to light up as it should
#18 | |
Using that red wire would be fine. I actually recommend following the DIY in the link below, which I created for Micro Image instead, as the one in this thread leaves the switching and illumination circuits bridged, which results in the light on the switch being illuminated, even when the car is off. http://microimageonline.com/forums/s...n-Instructions
| Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 02:18 PM |
| Looking for the Toyota Fog Light install | RocknRollRon | DIY / Maintenance / Service | 33 | 06-13-2010 07:46 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
| Before I start calling around: fog light install prices | St_G | Cosmetic Modifications (Exterior/Interior) | 4 | 03-17-2007 10:45 AM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 05:24 PM |
