Old 10-23-2008, 10:19 PM   #1
Appalachian Trail 2007
Appalachian Trail 2007's Avatar
Drives: 2008 Yaris LB
thanks for the help but I don't want a cruise control...I want a throttle control
3,441,567,453 posts BH (Before Hack)
Appalachian Trail 2007 is offline   Reply With Quote
Old 11-09-2008, 05:32 AM   #2
metalshark
MetalShark
throttle control
What you are looking for is a potentiometer with the same resistance curve as your throttle pedal sensor. You'd need to use an ohmmeter to measure the resistance of the pedal to get the right one. Then you need a 12 volt ice-cube relay with a start button and a seal-in to transfer control from the pedal to your new dial. The brake light switch could be used to disengage your control transfer relay if it had a resister in it's ground path of the right size. I've thought about doing this project as a DIY. You can get better mileage with this setup under hyper-mile concepts because you scrub off speed up hill and pick up speed down hill. I've already got Rostra cruise, but I think your a-barkin up the right tree with this concept.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Yaris.. Cruise Control. peanut New YARIS Purchase Forum 28 11-26-2017 06:17 AM
Cruise Control in the LB RobotMan In Car Entertainment + Electronics (audio / video / alarm) 1 09-30-2007 02:43 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
