Old 11-21-2008, 11:25 AM   #1
SuperFunBall
Drives: 2008 Blazing Blue 3dr LB MT
Marcus...at what mileage did you switch over?
Sometimes you have to spit on your hands, raise the black flag, and start slashing throats
SuperFunBall is offline   Reply With Quote
Old 11-21-2008, 02:54 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
24000 kms..
Old 11-21-2008, 03:44 PM   #3
SuperFunBall
Just curious. I heard that if you switch over too early before proper break in you could see a drop, but you switched over much later. You might want to try the new Mobile-1 OW-20 or 5W-20 on the next oil change to see if it helps restore some of that lost FE.
Old 11-29-2008, 02:43 PM   #4
Jeff E.
Drives: 2008 White LB
Originally Posted by natethegreat38 View Post
I still don't have enough miles on my car to have had the first oil change yet, but I heard that your mpg/ FE will improve slightly/dramatically once I get it changed for the first time...
Can you please share your experience?? Can you confirm/deny this??
Since the weather got cooler, I don't get anything beyong 36 mpg, even after my recent first oil change. My last was 35mpg due to 200 miles at 78 miles per hour on the interstate. So about 36mpg mostly hiway at 59 miles per hour top speed. Not the best.
I drove a Yaris Sedan for a while last summer and got 41-42 almost all the time.
Jeff E. is offline   Reply With Quote
Old 01-20-2009, 11:34 AM   #5
marcus
toyota
marcus's Avatar
i always thought that synthetic increase ur change period due to breakdown of the oil is a lot longer..if one will change the oil every specified change date is there a point to go to synthetic.
Old 01-20-2009, 01:13 PM   #6
kou
Drives: 08 lb
if you drive like a granny it probaly will last a little longer, but we only have 3.3 quarts it can't last being abused.
your motor will last forever if you change your oil with regular oil every 2500 and you filter every 5000 miles this will be cheaper than one synth change.
the synth oil is good if you like to rev it out with its stabilty at higher temps. change every 3500-5000 with a new filter, sooner if you rev it out.
Old 01-20-2009, 02:16 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
and they both get dirty at the same rate
Old 01-20-2009, 04:24 PM   #8
kou
Drives: 08 lb
if you granny it synth will stay cleaner longer in a stock car.it handles the heat better therfore not getting that cooked look so fast.
Old 01-20-2009, 05:40 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
wtf is granny it?
my poor oil gets cooked immediately.. god bless twin/cooled turbos or it'd be worse
Old 01-30-2009, 04:41 PM   #10
SilverGlow
Drives: 2007 Yaris Hatchback
Wow this thread contains lots of bool sheet.
What makes an oil dirty is fuel explosuin blow-by leaking from the combustion chamber past the rings into the oil. Syn and mineral oil get dirty exactly the same way and from the same causes.
SilverGlow is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
