Old 10-29-2008, 03:35 PM   #1
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Toyota Yaris MPG Review at www.mpgomatic.com
http://www.mpgomatic.com/2008/08/24/...is-mpg-review/
2008 Toyota Yaris S Sedan - Highway MPG Testing:
* 43.2 MPG - windows down, cruise control off, A/C off
* 43.8 MPG - windows down, cruise control on, A/C off
* 46.2 MPG - windows up, cruise control on, A/C on 50%
* 49.7 MPG - windows up, cruise control off, A/C off
(Specifics: 40 mile interstate loops, cruise control set at 66 MPH, 60-70 MPH range with cruise off.)
Impressive!
aca72 is offline   Reply With Quote
Old 10-29-2008, 07:12 PM   #2
gid
good find , thanks .
Old 10-29-2008, 07:24 PM   #3
Smokey159
Drives: Yaris Liftback
Interesting, most people on this forum say A/C off is always the way to go...
Apparently not?
Can't believe I'm modding a Yaris, I must really miss my STi...
Smokey159 is offline   Reply With Quote
Old 10-29-2008, 09:53 PM   #4
b_hickman11
Drives: 08 Sedan
Apparently not?
Having the windows door puts more air resistance on the car therefore you get lower mpg.
Old 10-29-2008, 09:57 PM   #5
Appalachian Trail 2007
Appalachian Trail 2007's Avatar
Drives: 2008 Yaris LB
A/c is more efficient after 40 mph. The drag created with the windows down is much higher than with the a/c on. The best way to use a/c on a long trip is to combine it with going downhill. If you're engine breaking and the dfco kicks in then turning on the a/c shouldn't use more gas, it'll just slow you down more.
3,441,567,453 posts BH (Before Hack)
Appalachian Trail 2007 is offline   Reply With Quote
Old 10-29-2008, 10:03 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by aca72 View Post
How do you get those numbers. I only get 30mpg with cruise on set at 70. Most i ever got was 34mpg
Old 10-30-2008, 12:21 PM   #7
b_hickman11
Drives: 08 Sedan
Could be several reasons why you're not getting the mpgs you should be. I have 2 Yaris's and I have never got less than 36 mpg. The highest I have ever got was 44 mpg. I do not use any hyper techs. and I use the AC all the time.
Old 10-30-2008, 10:20 PM   #8
YarisSedan
Hmm. How do you get your mpg. Do you take the amount of gas you fill your tank up to and take that number and divide it into the amount of miles you drove after your last fill up. I think that is the only accurate way to get your mpg average per fillup.
Old 10-31-2008, 12:03 PM   #9
b_hickman11
Drives: 08 Sedan
Yes
Old 10-31-2008, 11:40 AM   #10
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
They get pretty high numbers on all the vehicles they test.
428CobraJet is offline   Reply With Quote
Old 10-30-2008, 12:42 AM   #11
BailOut
Steals terrorist's lunch
BailOut's Avatar
Between all of us on this forum that have ScanGauges and over thousands of miles of testing we have each found the exact opposite of their results with the a/c usage. Without fail we can find little to no effect with the windows down at any speed but huge efficiency hits with the a/c on at any speed.
- Brian
Share the Road
Old 10-30-2008, 01:26 AM   #12
50MPGDream
50MPGDream's Avatar
Drives: 07 Yaris LB, 93 Camaro
I agree
-Aaron
50MPGDream is offline   Reply With Quote
Old 10-30-2008, 07:33 AM   #13
voodoo22
Drives: Yaris Sedan (auto)
+1
voodoo22 is offline   Reply With Quote
Old 10-30-2008, 09:26 PM   #14
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
I too agree with Bailout
roadrunner is offline   Reply With Quote
Old 10-30-2008, 08:56 AM   #15
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
LOL The next time I plan on using the AC to cool might be next May at the soonest!
My scan gauge tells me what is happening with my car!
Old 10-30-2008, 09:04 AM   #16
Mikeb Yaris
Drives: 08 Sedan Base Auto/PWR BLK
Not having a scan gauge, I do not wish to speak out of turn, but doesn't a scan gauge have to be "calibrated" to the car via a couple of fillups and adjustments?
Mikeb Yaris is offline   Reply With Quote
Old 10-30-2008, 11:00 AM   #17
Astroman
Modded Moderator
Astroman's Avatar
yup. I really don't use mine to get "optimal" mpg, but to stop me from using that lead foot.
Old 10-30-2008, 11:10 AM   #18
Mikeb Yaris
I just mean to inquire as to the accuracy of these numbers. As I understand it, one does not just plug in a scan gauge and get accurate mpg numbers right off the bat. They do not discuss making adjustments to the device to fit the particular automobile based on actual consumption measured at the pump. They just give the SGII readings, which as I understand it, aren't even close to accurate until the device has been adjusted over a couple tanks.
I'm all for reporting great mileage for the car, but it doesn't mean anything if it isn't done precisely.
Toyota Yaris S Mod jamal1984 Performance Modifications 10 01-07-2007 02:48 PM
