#91 |
![]() ![]() Drives: Toyota Yaris T SPORT Join Date: Feb 2006
Does anyone know how low can you go on coilovers without rubbing on 195/50/15?
#92 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Pretty darn low. I'm nearly at full UP in the rear, and the fronts could go down a lot more if you're going for a show car look. It'd be miserable to drive that low, though.
Subcompact Culture: The Small car blog |
#93 |
Thanks for the info! It would be a miserable ride even with coilovers?
#94 |
The Megans are pretty stiff, even at soft settings. If you're looking for a nice, soft ride with coilovers, check out the Tein Basics.
#95 |
#96 |
having the same problem with mine...gotta take the fronts apart tomorrow....
damn megans and their no instructions...
#97 |
Did you get your problem solved?
#98 |
sorta..might have been using the wrong bolt at the top of the bearing
also lowered the height in the front another 1/2". still sits a bit too high above the strut top, but ill live with it, i guess
#99 |
I need more stars
Drives: Liftback Join Date: Jun 2009
Silly question but how do you adjust the height for the rear? Is it the spring or the damper?
#100 |
perch for the spring for height
#101 |
Reluctantly Crouched...
I'm resurrecting this thread in hopes that 39 might post that DIY/pics he promised?? :)
If nothing else, how did you go about pressing-out the strut bearings? There is a lot of great info about these coilovers in this thread, it just takes a while to find it. Any chance you can post some dimensions/settings for your current setup? Like, how much rear shock thread is showing? How much preload did you end-up going with? How low did you drop it without lots of rubbing? Thanks! the thread alone has been mucho helpful. |
#102 |
#103 |
Thanks. A picture really is worth a thousand words!
#104 |
Hey guys! Im really trying to understand this install, but can someone give me some info on the rear shock to begin with? I dont quite understand the purpose of the threads on the bottom of the rear shock? What is it used for and how do I adjust it?
Thanks!
| Megan Springs? | churp | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 06-06-2007 03:11 PM |
| Megan or Tein suspension | elmercurrie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 43 | 05-31-2007 09:41 PM |
| Comp S Coilovers for a discount and installed | BulletProofAuto | California | 1 | 05-12-2007 01:04 AM |
| cusco coilovers installed | badhabitz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 02-03-2007 04:43 PM |
| Tanabe NF210's installed...got a question though | Terrorize | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 09-29-2006 07:45 AM |
