![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
Nice pictures, now could someone with a sedan do the same?
![]() Drives: 2008 Yaris 5M Blazing Blue HB Join Date: Oct 2008
I think the Sedan is the same, it is just that the rear jack point is in the middle instead of more to the passenger side.
![]() Drives: RC yRs LB Join Date: Jul 2007
i use a lift. since i do work a at dealership
Drives: Yaris Join Date: Nov 2010
i just use the side jack point closer to the front of the car (behind the front wheel) and jack it all the way up....i do one side at a time for rotation.....
so rear passenger --> front passenger and front passenger --> to rear passenger then i do the same for the drivers side... this way i only have to jack up once per side and it works whether you have direction tires or not....
^ same as the jack points. My car has been on a lift more times than I can remember. If you don't want to mess up that lip underneath, insert a slotted block to preserve it.
WHy dont you ask for help at a tire place and put the car on the lift, my dealer does it free...
It saves a lot of frustration.... its quicker.
--------------------------------------------------- “Do or do not... there is no try.”
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Tire rotation
I went from the Toyota dealer when I picked up my Yaris and purchased a tire warranty from Discount Tire. I paid for itself the first time I ran over steel through the side wall. Discount has been balancing and rotating them for free for four years now. I've got 58,000 on the BridgeStones and wear bars are showing on all four. The only time they went out of balance/round badly was when my son was learning to drive. They stay round and in balance longer at 74 MPH than they do at 55 MPH. Go figure.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
#9 | |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
![]() Drives: 2011 3-Door Liftback Join Date: Sep 2011
If I lift up the front from the center lift point using a floor jack, and I want to put the front of the car on jack stands, where would I place the jack stands? Are there front side lift points, like the rear side lift points? Thanks!
You would have to put the jack stands where the jack points are on the pinch seam behind the front wheels.
They are actually meant to be supported by a slit block, like the top of the OEM jack, as opposed to being supported by the edge. Prior to getting my lift I would lift the car from the center point and use my old jack stands under the seams. My jack stands have narrow tops, so I couldn't use the slit hockey pucks that I use when jacking at the seams. There is a bit of paint chipping on my seams from my stands, but no signs of deformation. With my lift, I actually lift it by the four pinch seams, but my lift has 6x6 pads with 1/4" thick rubber, so the pressure is well distributed.
I've read that the suspension needs to be loaded when changing struts or other suspension work. Is there any safe place to place jack stands that loads the suspension, or do you just need ramps for that?
Edit: My secondary motive for this question is that jack stands at their normal positions are in the way of the belly pan I'm installing. Last edited by spookybathtub; 02-01-2015 at 05:04 PM. |
Hockey pucks, that's interesting. Regular hockey pucks from the sporting goods store, with slits that you cut in yourself? Thanks again!
Exactly. I got the idea a couple of years ago from someone else on here. I bought a 10 pack at Sports Authority and ran them through the table saw, making a slit about 1/4" wide by 1/2" deep. After a while they start to crack at the bottom of the slit, so the next time around I would probably use the router table instead and make the cut rounded at the bottom.
My old, heavy floor jack lifts both front and back tires when positioned under the rear jacking point. Things a back-breaker to carry but does the job just fine.
#18 | |
Great tip! Thanks! Now I just need to figure out how to get those to stick to my jackstands. =) Will definitely use that technique with my floor jack right away. The puck will fit nicely into the top of that. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Yaris Crashed! | elsteverino889 | General Yaris / Vitz Discussion | 13 | 11-06-2006 02:59 AM |
