Old 04-03-2012, 01:35 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Like crap?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-03-2012, 01:46 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Thats a shop here in Tampa. Are you sure that is for the 1nz?
Old 04-14-2012, 10:12 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
this stuff is more exciting that porn! i want 400hp yaris! power to weight would leave mustangs and camaros in the dust.
Old 05-12-2012, 10:53 AM   #4
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
After running in the engine, I had the car sent back for a tune today and things got interesting.
Blue curve - 404 whp, previous base tuning for engine run in, pump gas, 1.6 bar boost, no water/meth.
Red curve - 454 whp, pump gas, 1.7 bar boost, water/meth turned on.
Green curve - 501 whp, pump gas + avgas 50/50 mixture, 2.2 bar, no water/meth.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 06-27-2012, 09:16 AM   #5
Hussain-Vtec
Hussain-Vtec's Avatar
Drives: ECHO NCP-12/2NZ-FE
That Nice Curves in Both Congrats.
Time to
***High-Performance Cooling System***http://honda-tech.com/showthread.php?t=3062009
***The Basics of Reading a Spark Plug***
http://honda-tech.com/showthread.php?t=3063102
ALL-TECHwire
Hussain-Vtec is offline   Reply With Quote
Old 07-05-2012, 05:51 PM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That's a tough act to follow!
Here's the results of my baseline dyno runs.
The engine is bone stock except for:
Weapon R Short Ram Intake with BLOX Velocity Stack Air Filter
Weapon R 4-2-1 Exhaust Header
Mirco Image MagnaFlow Center Exit Exhaust
100 horsepower and 100 foot pounds is not too bad considering just those few mods.
The torque curve is pretty flat overall and peaks at 4,000 rpm.
Old 07-07-2012, 12:01 PM   #7
Hussain-Vtec
That is Nice.
Question what Do you use for tuning your ECU?
Do you have any idea About the Camcon VVT-I Controller
I hear its a nice tuning device.
Old 07-07-2012, 12:15 PM   #8
tooter
play every day
tooter's Avatar
Originally Posted by Hussain-Vtec View Post
That is Nice.
What tuning?
I just ran the car as it was. However, I did disconnect the battery after putting on the short ram intake so that the ECU had plenty of runing time to readjust to the new operating conditions.
Harry did 4th gear pulls that you could time with a calendar!
After the first one, he asked if I wanted third gear pulls, but I wanted all the pulls to be done under exactly the same conditions to get consistent results.
Old 05-12-2012, 11:04 AM   #9
That's crazy - CONGRATS on pushing the 1NZ to the new record power levels. 2.2 bar is about 30 psi, right?
Any idea why the power is so much higher than the torque? The gap between the two seems to grow the higher you go with boost and power.
Any videos of a pull? I bet it sounds great at 8000 rpm.
Old 05-13-2012, 10:59 AM   #10
I'm guessing turbo choice...
And HP = (tq x rpm) / 5252....so at high rpm you need less tq for big hp
Old 05-12-2012, 12:34 PM   #11
changchewsoon
Drives: Vios Turbo
Hi Garm, I am currently uploading the video to YouTube at the moment.
Not sure why the torque curve is like this, maybe the 1NZ engine is not meant to produce a lot of torque?
But we do know that the power is still climbing at 8000 RPM. Not sure how it'll go if we give it another 1000 RPM.
Old 05-12-2012, 01:45 PM   #12
wowowowowowowow crazy good stuff!
Old 05-12-2012, 02:18 PM   #13
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
holy shit balls batman!
and the winner goes tooo
-Derrick-
Old 05-12-2012, 02:24 PM   #14
vten
Holy batman robin n iron man ...
500 plus on a Yaris ... Even on my AMG with double the Yaris weight I get scared sometimes with the traction control off ....
Old 05-12-2012, 05:20 PM   #15
Golddeenoh
Golddeenoh's Avatar
holy sheeeet 32psi. big boost there big pimpin.
Old 05-12-2012, 05:20 PM   #16
holy Avengers...
what's "avgas"? some kind of race gas, I'm guessing?
Old 05-12-2012, 10:12 PM   #17
changchewsoon
Drives: Vios Turbo
We call them avgas on our part of the world, perhaps it's better known as aviation fuel on your side?
Old 05-12-2012, 10:32 PM   #18
Golddeenoh
Golddeenoh's Avatar
ahh we tend to call it "Jet Fuel" and depending on the grade maybe even "Race Fuel" or "Race Gas".
WR Yaris Intake Picture & Dyno. WRLEO Performance Modifications 37 04-05-2007 07:02 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
