#19 | |
Audio Junky
i drive 70% highway and 60-65 while on the highway. I try to reduce the amount of times i have to start & stop as much as possible... I figure stopping & starting is probably more wear on your tires as well as less mpg's when I fill up. |
#20 |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
90% highway, 70 mph, 32 psi on my 07. So far the ones on my 08 are wearing fine. Maybe they just had a bad crop in 07??
#21 | |
#22 | |
![]() ![]() Drives: '10 Fit Sport MT and 2012 Fit Join Date: Oct 2008
Tire rotation is an old thing when cars had horrible alignment issues and had to have tires rotated. These days it's just a way for service technicians to earn a living... just like 3,000 mile oil change. |
#23 |
Front tires turn....rear tires do not....this causes a different wear pattern on the front and rear tires. This is why you rotate, but I guess the multi-billion dollar tires companies dont know what they are talking about.....
#24 |
![]() Drives: 2008 Yaris 5M Blazing Blue HB Join Date: Oct 2008
Well, I rotated my tires this weekend, back to front, jacking up one side of the car at a time. The difference in tread wear was obvious. I have 5,200 miles on the car.
I've always rotated the tires on my cars so they wear evenly. When the time comes for new tires I always buy four new tires and the process starts again. For those keeping track, I am now 97% sure where the front jack point is located. Does anyone have a nice picture of it?? |
#25 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Anyone use ramps instead of jacks?
#26 | |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
On a side note. I don't care what psi people are using. However, I have been involved in 2 personl injury lawsuits involving lawyers and insurance companies. I wouldn't put anything past either of them. If you are driving with over inflated tires and posting your psi on the internet and get into an accident caused by a blow out, the insurance company or lawyer will find a way to use that information against you.
Making a decision without following it with an action is still a fantasy. Last edited by nemelek; 11-09-2008 at 05:50 PM. |
#27 |
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S Join Date: Oct 2008
wouldn't the wheels then be sitting on the ramps instead of the floor? Or was this a joke and I just didn't catch the tone?
#28 |
I was just stating that he was following the tire manufactor's max rating of 44 psi and saying Toyota's recommendations where a joke. He also said that the tire manufactors rotation guidelines where a joke and that he followed Toyota's. So therefore he is follow the tire manufactors guidelines for one thing but following Toyota's for another.....
#29 |
#30 |
Haha ok, guess I got sidetracked on the whole rotating tires stuff.
I used ramps to install my exhaust on the car, but I couldn't use ramps to get under the front because my car's dropped and the ramps are just a bit too steep.
#31 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Factory Bridgestones good for 50,000+ Miles
Tire rotation on today's cars is a must and the ONLY way to squeeze out the most milage from tires. It is as relevent today as it was 100 years ago. Surely you're not so ignorant to realize that the front tires will wear two or more times faster then the rear, yea?!? I run the original Bridgestone tires that came on the 2007 Yaris Hatchback, and I over inflate to 50 PSI, and get this: I'm at 48,000 miles and can easily reach 50,000 and still have thread left. So how and why you guys are getting sheet milage from your Bridgestones is beyound me...it must be your lack of good driving habits and lack of tire rotation. The proper way to rotate radial tires is front to back, back to front. Only the old bias ply tires switched sides of the car....never do this with today's radials.... |
#32 | |
Guess where Toyota gets the recommanded PSI from? The. Tire. Company. In addition, it does not matter if the car is 4x4 or what it weighs because the amount of air needed to put a tire to a particular PSI differs according to the weight of the vehicle. So our Yars, for example needs less air in the tires for 35PSI then if the car weighted say 500 lbs more. In other words, all you have to do is add enough air to bring the PSI to the proper level... |
#33 |
#34 |
Yes, cross rotation will mean faster and uneven wear.
Talk to any tire tech and they will tell you that radials must stay on the same side of the car. Switching sides when rotation worked great years ago when tires were bias ply. But nobody makes bias ply for passenger cars anymore. |
#35 | |
DWEED
There is probably an industry guidelines for tire type and sizes. The amount of load on a tire and the corresponding the PSI are in those guidelines. It's Toyota's responsibility to pick a correct tire and recommend the proper PSI. The weight of a vehicle does matter. If the Yaris was a 1,000 pounds heavier or lighter their might be a different tire or PSI recommendation. On the chart below for the Dodge Ram you will note that the front tires for a light load with the diesel require 10 to 15 PSI more than the V-8. Why? Because the diesel weighs a lot more. Notice when the truck goes from light load to heavy load the PSI for the rear tires go from 40 to 70 or 80. Why? Because as the weight increases there is an additional need to increase the PSI. There are some idiots that would put 120 PSI in the rears. Do you really think that "The.Tire.Company." made this chart for Dodge? More likely Dodge engineers figured the load for the tires in different situations and used the tire guidelines from the manufactures put together this chart.
Making a decision without following it with an action is still a fantasy. Last edited by nemelek; 11-09-2008 at 05:52 PM. |
#36 |
DWEED
I may be stu--- but at least I can spell recommended.
Making a decision without following it with an action is still a fantasy. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Yaris Crashed! | elsteverino889 | General Yaris / Vitz Discussion | 13 | 11-06-2006 02:59 AM |
