Old 09-27-2006, 02:18 PM   #1
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by IsLNdbOi
Does the hi beam / low beam kit use debased bulbs that are hard to get replacements for?
Finally, if the hi beam / low beam kit does use debased bulbs, is there any way to get ones that are between 4300 - 5000k?
4300 to 5000k bulbs are supposedly the best types to use when using stock reflectors instead of using projectors.
Debased bulbs?
Chris07LB is offline
Old 09-27-2006, 03:41 PM   #2
IsLNdbOi
IsLNdbOi's Avatar
I meant rebased bulbs.
IsLNdbOi is offline
Old 09-27-2006, 06:02 PM   #3
Chris07LB
Chris07LB's Avatar
Again, these kits are H4 fittment, exactly what comes original equiptment size in your Yaris.
There is not "adapters" to make them from one size, to another.
To answer your last question, I believe he has a few different K ratings to choose from, but comparing light output to headlights with or without projectors, is like comparing apples to oranges.
A projector retrofit with HIDs, is hands down the best way to go, if you know what your doing to make it work correctly.
Old 09-27-2006, 06:25 PM   #4
IsLNdbOi
IsLNdbOi's Avatar
I've been asking around HIDPlanet for some advice and they told me that if I'm gonna be doing a drop in kit and be keeping my stock reflectors then the best k rating to use are between 4000 to 5000 k bulbs.
IsLNdbOi is offline
Old 09-27-2006, 07:42 PM   #5
Chris07LB
Chris07LB's Avatar
Thats correct. Most "useable" light.. Just about every car company that has HID/Xenon's as factory equiptment, uses bulbs in that K range.
From experience, 8oook and 1o,oook may look nice, but you cant see the road for chit! These bulbs in this original post of mine, and the ones I am currenty using/selling, are labled I think higher then they should be... this is a nice crisp bright white with what I have now. No where near the bluish/teal color like the higher K bulbs.
Old 09-27-2006, 08:01 PM   #6
IsLNdbOi
IsLNdbOi's Avatar
Excellent. Now I have to decide whether I want to get fog lights or your HID kit first.
IsLNdbOi is offline
Old 09-27-2006, 10:30 PM   #7
IsLNdbOi
IsLNdbOi's Avatar
The Yaris uses a single bulb for low beam and high beam so if you got the low beam kit, you'd have low beam only. At least that's what I got from all of this.
IsLNdbOi is offline
Old 09-28-2006, 01:14 AM   #8
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
interesting. well then I guess I'd like to purchase the high/low beam kit.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline
Old 09-28-2006, 11:44 AM   #9
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
From your first post on this thread:
My kit is made by Nuxen...
Thanks for clearing that up.
Actually, shouldn't that be "EAGLEYE"?
Violin is offline
Old 09-28-2006, 12:49 PM   #10
Violin
Violin's Avatar
Do you know if the High/Low is kit plug & play as well or does it require any cutting of the housing?
This is what has me concerned: (see step #1): http://www.namyung.co.kr/english/hotproduct/hidh4.asp
It may just be drilling a small hole for a mounting screw.
Violin is offline
Old 09-28-2006, 01:41 PM   #11
IsLNdbOi
IsLNdbOi's Avatar
I couldn't find Eagleye's website, but found this (maybe this is their website):
http://plasmagarage.com/index.html
IsLNdbOi is offline
Old 10-05-2006, 08:06 PM   #12
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
EagleEye and SmartEye are essentially the same brands.
They are manufactured by Guangzhou Hinux Electronics Co., Ltd.
Yes, you guessed it, that is a Chinese manufacturing company.
Nothing to fear, as SmartEye/EagleEye kits are good quality from what I've read and heard.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline
Old 09-28-2006, 01:49 PM   #13
Violin
Violin's Avatar
No - this is it: http://www.namyung.co.kr/english/index_eng.asp
Violin is offline
Old 09-28-2006, 02:08 PM   #14
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Would you be able to get the high/low?
nick1983 is offline
Old 09-28-2006, 05:21 PM   #15
Violin
Violin's Avatar
I can answer that - Yes.
I'm probably going to get a set myself. I'll share my impression of them here if I do.
Violin is offline
Old 09-28-2006, 07:52 PM   #16
Chris07LB
Chris07LB's Avatar
High/Low's require NO MODDING/CUTTING Etc. of your housing..
Difference between the single low beam, and high/low beam H4 kits, is the high/low base of the bulb is extended (longer) then the single.
This, again, is like the HID/xenon used on the Toyota Prius. When engaging the high beams, the actual bulb itself, "snaps" back and up, to project the light "up wards."
I need to gather up all my post reply's, as Im repeating myself over and over..
Old 09-28-2006, 07:59 PM   #17
IsLNdbOi
IsLNdbOi's Avatar
Go to this site to see more about the kit Chris is selling:
You'll see pics. of the ballasts, harnesses and the high / low beam HID bulb used in the kit. Also, their price for the kit that does high / low beam is $328.75 shipped via 2 day UPS.
I'll probably buy the kit from them and then replace the ballast that the kit comes with, with some Denso ballasts that Toyota uses in their other cars.
Chris, sam07 said this:
"I am happy with the results and during the process of my HID retro I noticed at the bottom of the headlights there is a square space with screw holes into it. I noticed that this resembles an HID ballast location for our headlights *OEM fitment* as well as the D4R classification implanted in the back of the headlight*hid bulb* also."
Did you notice these square spaces for the ballasts in your LB?
IsLNdbOi is offline
Old 09-28-2006, 08:03 PM   #18
Chris07LB
Chris07LB's Avatar
PM me for lower prices then that site.
Here's how the high/low kit looks.. notice the difference in bulb base, compared to the single H4 bulbs.
http://plasmagarage.com/H4BiXenonIns...otaTacoma.html
Be sure to play their quick video to see them in action!
