Old 08-13-2006, 06:15 AM   #1
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
HID - Seeking Advice on Equipment, Installs, Kits, etc.
I've decided that my next mod will be a HID setup for the front lights, with a JDM tail light conversion in the near future.
I have never installed a HID on a vehicle, and I am seeking advice on which equipment to purchase.
Are there any particular kits or brands that are suitable for the Yaris?
There are numerous universal kits that are on the market; are they acceptable for installation to the Yaris?
What equipment is required, and what sort of work needs to be performed?
Awaiting your expert opinions!
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 08-13-2006, 06:47 AM   #2
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
bigsky, the only thing you'll need as is with the Yaris is HB3 Rebased HID bulbs, a ballast/igniter, and optionally... but recommended, a harness. The only problem is since the Yaris uses a Dual filament bulb, you'll lose hi-beam, the only other option is a retrofit of say... a bi-xenon projector unit, which is a lot more involved. Chris07LB has done a kit-in, so maybe he can recommend a kit to you.
paultyler_82 is offline   Reply With Quote
Old 08-13-2006, 10:22 AM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
I sell/install the EagleEye brand kits now. Just actually swapped my other HID kit out last night for the EagleEye.
Now you do have some choices here..
(1) You can get a single beam (low beam only) H4 kit, which includes a WATERPROOF ballasts with built in igniter, HID bulbs, all wires, and a mounting bracket (not needed) to mount the ballasts.
(2) You can get a High/Low (high & low beam) H4 kit, which includes everything mentioned above, PLUS the wiring harness/relay needed for the High/Low kit. The beauty of this kit is, one you get high beams, but most important, unlike other High/Low kits out there, the high's are BUILT into the HID bulb assy.! Other brands use a small little halogen bulbs, attached to the HID bulb, that has a chance of one day buring out, and needing to remove your HID bulb assy., to replace. That and it also looks like a cleaner install, without the little halogen stuck in there!
PM me if you have any other questions.
Old 08-13-2006, 01:40 PM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Will the low beam only kit get through NJ inspection (in 4 years)?
Old 08-13-2006, 07:14 PM   #5
Chris07LB
Chris07LB's Avatar
I am told NO.
BUT, all thats needed is to remove two wires, and the HID bulb.. swap in your stock bulb, and plug the harness back in. Everything can stay mounted and installed, so withing 5 minutes you can switch back to boring halogen to pass inspection.
Old 08-14-2006, 12:45 AM   #6
riceboy
Drives: icebox
Hey chris... you got a shop down in jersey?
riceboy is offline   Reply With Quote
Old 08-14-2006, 02:56 AM   #7
paultyler_82
Hey Chris, how's that High/Low kit work? does it use a Solenoid or what?
Old 08-14-2006, 02:02 PM   #8
ChinoCharles
Drives: LB
Chris, check your pm's.
Old 08-14-2006, 06:55 PM   #9
Chris07LB
Chris07LB's Avatar
Nah, just our freshly built 1300sq foot garage at home.
Old 08-14-2006, 09:30 PM   #10
bigsky2
Cousin Vitz
bigsky2's Avatar
Excellent advice everyone, thank you.
Chris, check your PM :)
Old 08-14-2006, 10:48 PM   #11
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
i want ur garage christ :p
OxyG3nE is offline   Reply With Quote
Old 08-15-2006, 12:54 AM   #12
riceboy
Drives: icebox
1300 sq. ft garage.. damn... we should organize a CAN/US meet in your garage!!!
Old 08-15-2006, 10:36 AM   #13
Violin
Violin's Avatar
Thanks for getting back to me on the pricing Chris. I'm considering the hi/low kit.
1) Would I have to disable the daytime running lights?
2) How long can you expect the bulb to last? About how much to replace when they go?
3) That garage is larger than my first home.
Old 08-15-2006, 07:07 PM   #14
Chris07LB
Chris07LB's Avatar
Well my driveway should hold about 20 Liftbacks, besides the garage space.
Old 09-01-2006, 06:03 AM   #15
bigsky2
Cousin Vitz
bigsky2's Avatar
Here's my next question for those that have installed HID:
Is a projector required to achieve a SAFE cut off for the light output?
Or is the halogen housing (existing stock housing for halogen bulbs) sufficient and produces a SAFE cut off for the light emitted by the HID?
I'm all for looks and performance, but I do not want to be a danger to other drivers.
Awaiting your responses!
Old 09-01-2006, 08:51 AM   #16
Chris07LB
Chris07LB's Avatar
You be the judge..
Old 09-03-2006, 01:12 PM   #17
Lafiro
Drives: 06 Yaris Sedan
I had a kit installed by a friend. And lets just say that stupid storm that came to the northeast caused a little damage. A fence hit the side my my car, my HID buld got a bit of water and blew out on 1 side. Yeah Im really not having a good day.
As for the nice dent and missing paint, I cant fix right now,, but as for my HID being out, where in the world can I buy a replacement D2R bulb ( 6000 k, originally Philips brand )
Thanks, In zip code 11368. Any stores/prices would be greatly appreciated cause I need a replacement bulb asap.
Old 09-03-2006, 02:08 PM   #18
Chris07LB
Chris07LB's Avatar
First of all, water should have NEVER seen the bulb/headlight housing! Something was installed wrong, or your friend didnt take the time to re-install the factory dust/water boot.
What kit are you using? If you are running a D2S or D2R bulb, surely you have an H4 to D2 adapter inside your housing??? If not, you got one hokey install my friend.
You never got back to my PM about the install, but I guess you won't be needing it now anyway.
Let me know if you need any help, getting a good set of plug and play HIDs for your setup.
