Old 04-16-2015, 04:18 PM   #1
33OH
Drives: '08 Yaris
Damn, 15's are pretty impressive with just a few mods.
Old 04-27-2015, 08:42 AM   #2
S2robbin
Drives: Toyota vitz RS
2007 Vitz RS non-turbo
1nzfe manual
16" original rs wheels
broke both bee hive stone thingy in the cat kept the stock resonator and stock piping and a cheap ebay mufler with silencer
engine is bone stock with stock air filter
File Type: jpg 11188367_939917646032386_1022010123735654763_n.jpg (53.0 KB, 113 views)
S2robbin is offline   Reply With Quote
Old 01-03-2016, 02:36 AM   #3
EchoLaQua
EchoLaQua's Avatar
Drives: Toyota Echo Turbo
2000 Echo
- 1nz
- Standard 2nz gearbox
- Custom manifold
- TD04L (wrx turbo... Super laggy on the 1nz)
- 2.5" dump/exhaust
- Xr6t front mount
- 14x7 rebanded steelies wrapped in the cheapest 185/60's around (32psi)
- Full tank of fuel/sub/power tools/spare wheel
wheel
15.0! Was my first time at the track so I think I did pretty well. Only got in one run.
Barely got traction till a quater of the way through second gear. So with a bit of weight reduction, better/deflated tires, dialing in the gain on the ebc (which I'm yet to install) and of course, more practice, I think I'm a chance of a high-mid 14.
EchoLaQua is offline   Reply With Quote
Old 04-07-2017, 02:14 PM   #4
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Not a Yaris or a 1NZ, but a 1NR-FE and I know there are a few other guys here with 1NR-FEs. Heading to the track and reserving this space for timeslip and modification list. Trying to beat the Motorweek record of 17.4 @ 80mph. Fingers crossed for a 16.999 run or better, but my goal is only better than Motorweek.
***UPDATE***
I managed to get 6 runs in before the CVT was too heat-soaked which resulted in my retirement to go home. Looks like I'll be needing a secondary small aluminum radiator before the CVT to aid in cooling.
In any case, I made my goal to beat Motorweeks best factory time of 17.4 @ 80mph (mostly). I managed a 17.348 @ 79.10mph with headwind gusts of 25mph (pics in comments) and a gradual incline from the line to the traps of around 6-12 feet. Over all, I'm satisfied for a car with 94hp and 89tq and although a 16.999 would have been nice to see, I'm sure I'll manage it at some point in the future.
Thanks to a friend, who managed to record a video against an Evolution X, that somehow only managed a 16.091 @ 97mph to my 17.348 @ 79mph. So here's the vid, with pics and other info.
Modifications - 1ZZ throttle body, K&N drop in filter with velocity stack forward facing on airbox, DC Sports catback exhaust.
MugenRep is offline   Reply With Quote
Old 04-07-2017, 05:55 PM   #5
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Good luck!
On Instagram
On Wheelwell
Old 04-08-2017, 08:51 PM   #6
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
Originally Posted by ern-diz View Post
Good luck!
Thanks Sir!!! All updated above!
Old 04-10-2017, 01:03 PM   #7
ern-diz
ern-diz's Avatar
Looks like you gained some good knowledge/experience on how the car performs and managed to beat the Motor Trend numbers --all while having a good time. Super cool.
On Instagram
On Wheelwell
Old 04-10-2017, 01:46 PM   #8
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
Yes Sir! Wasn't my first time at the strip, but it was definitely my first time with any sort of automatic (previously with my supercharged Ep3 running 13.8 at 105mph). Launching in this car is going to require some experimentation as it only revs to 2200rpms and doesn't seem to want to come up to the full 6250 rpm very quickly from a stop. I saw on a few other boards that people lightly let off and slam their foot back down to engage a computer response that encourages a steeper variable gear to be chosen. I don't know though as I've yet to try it. Yesterday morning I also made sure to change a few things including fully gutting both primary and secondary cats (seems like it made a difference, but who knows). Now to install the Camcon, take the backseat out, put my lighter motorcycle Deka battery (made for liter bikes), get some thermal material and see if I can add a gasket between the block and intake manifold, and do a Maxbore port and polish. Then see what it can do in a 1/4 mile run.
Old 04-13-2017, 04:09 PM   #9
ern-diz
ern-diz's Avatar
Man, you've got what sounds like a good plan to me. Deka battery, interesting. Is the trade-off just not lasting as long, or?
On Instagram
On Wheelwell
Old 04-13-2017, 04:13 PM   #10
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
Thank you, Sir! I did have a Deka ETX for awhile on my Ep3 and it did have a shortened life of about 2 years versus 5-6 of my previous Red Top Optima battery. CC amps are lower at around 200cc to 320cc depending on the Deka chosen.
Old 12-26-2020, 05:14 AM   #11
RomanDave
Drives: 2NZ ITB NCP10
2005 NCP10
2NZFE with ITB, ebay header and Link G4+
16.434 @ 83.24mph
2.62 second 60ft
When the car was stock it did a 17.6 @ 77mph and 2.5 second 60ft.
So it could have gone faster again but I only got six runs and wasnt doing any burnouts.
Will have another go when I've got a 1NZ and C56 in there.
RomanDave is offline   Reply With Quote
Old 01-02-2021, 02:39 PM   #12
Turbiini
Drives: 1983 carina 2NZ-FTE
not yaris but engine is, car rwd carina about same weight than yaris verso.
2NZ-FE
Custom intakemanifold
bosch 957cc ev14 injectors
Masterpower r494 turbo
migrosquirt module
cp pistons 10.2 comp ratio
autoverdi conrods
w58 tarns from mk4 supra na
hilux lsd dif.
fuel e85
stock cams
brian crower valve springs
Turbiini is offline   Reply With Quote
Old 11-29-2021, 04:29 PM   #13
RomanDave
2005 NCP10
Prius Type C 1NZFXE with Silvertop ITB
Link G4+
standard header and exhaust
JUN 264 cams
BC valve springs
C56 gearbox.
14.74 @ 94.6mph
2.572 60ft
So definitely some good potential to go quicker with a good launch.
A decent exhaust would likely help a lot too!
Old 01-19-2022, 06:47 AM   #14
RomanDave
Ran a 13.8 @ 99 mph
Stoked!
Faster than I thought an NA 1NZ would be.
Old 04-09-2022, 04:33 AM   #15
RomanDave
I ran a new PB, but the timeslip has awful printing on it that's hard to read.
Important parts:
60ft: 2.09
Quarter mile: 13.49 sec
Trap speed: 99.5mph
Happy with that!
Here's a video of the run.
https://www.youtube.com/watch?v=EsjwkvBHAqI
Old 12-14-2022, 02:41 AM   #16
ardianpradana
Drives: White Yaris J M/T
Send a message via MSN to ardianpradana
last weekend at sentul drag fest 2022, indonesia
16.204
in indo drag race, we didn't get the timeslips, so we used the time from the official results
will replace the heavy OZ futura for lightweight enkei for next year, hopefully this car will run constant 16.0, as the class I participate is index 16.0 class
in Indo there's 1500cc NA class, but the regulation is unclear so I'm not joining that class
ardianpradana is offline   Reply With Quote
Old 09-28-2009, 11:18 AM   #17
Astroman
Modded Moderator
Astroman's Avatar
Originally Posted by camelll View Post
Yeah was hoping it would be better, what can you expect from a autobox.
How about a 16.9 from my autobox, NA. I lowered my pressure to 26-28psi on stock wheels/tires in the front. You should get better times that way.
P.S. Thanks for posting your slips!!
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
