Old 05-25-2009, 10:42 PM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
Ok so a few days ago I did this. I added a switch. And it worked perfect for a few days. But now the light flashes and when I turn the switch off is stays on (doesn't flash).
Old 05-25-2009, 10:48 PM   #2
Measure the voltage on the brown wire.
Old 05-26-2009, 05:48 AM   #3
regal
Drives: 09 Yaris 3 Dr White LB
I'm not getting any voltage off the brown, white, or red wire, where is the fuse for this thing?
regal is offline   Reply With Quote
Old 05-26-2009, 06:21 AM   #4
It's the ECU-IG 10A fuse.
Old 05-26-2009, 06:29 AM   #5
regal
Thanks where would that be located?
Old 05-26-2009, 07:34 AM   #6
In the fuse panel that faces the driver's side floor mat at the bottom left of the dash.
Old 05-26-2009, 07:43 AM   #7
regal
looks like I'm buying an 09 service manual there is no such fuse in that location
Old 05-26-2009, 07:47 AM   #8
TIRE AND WHEEL TIRE PRESSURE WARNING SYSTEM ECU Power Source Circuit (2009 Yaris).bmp
Old 05-26-2009, 07:59 AM   #9
regal
nothing there but I butch of relays, no fuses
Old 05-26-2009, 08:54 AM   #10
regal
are these odd ball fuses or something?
Old 05-26-2009, 09:17 AM   #11
You're looking in the wrong place. Lay on the floor and look up at the bottom of the dash (directly under where you are looking). You'll see a plastic panel with the fuse locations. Pull that plastic cover off and the fuses will be visible.
Old 05-27-2009, 06:19 AM   #12
regal
found it thanks a bunch
Old 05-28-2009, 09:14 AM   #13
regal
but now when I turn my headlights on the instrument panel goes dim, under daytime running lights the dash is illuminated, very odd and can't find anything in the owners manual.
Old 05-28-2009, 09:40 AM   #14
That's the normal behavior for the instrument panel lighting - Full bright with headlights off and dimmed, per the knob, with headlights on.
Old 05-28-2009, 10:06 AM   #15
regal
I'll figure out this Toyota eventually. Thanks again.
Old 05-30-2009, 07:31 AM   #16
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Your Yaris has daytime running lights?
Old 05-30-2009, 07:49 AM   #17
regal
yes 09, found it was just the dimmer switch turned off, for some reason the dimmer switch dims the dash only when the headlihts are on.
Old 05-30-2009, 01:45 PM   #18
Yaris Hilton
Smile
My '07 & 2 '09s have normal headlights that you have to turn on, no DRLs. (Thankfully!) Must be a state law thing.
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
