![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
doc |
2ZR swap. DO IT! Ask how!
Now that I read it and understand it, the mod looks good!
Yes I read the whole thing through a few times. (and I may read it some more!) Im used to buying $300 cars and fixing them (well...$300 cars 20 years ago) but this ECM stuff I have no clue. Thanks for figureing this out !
![]() Drives: 2014 Yaris 3-Door Join Date: Oct 2008
Thank you for the simple TPMS mod, CTScott!
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Hi CT, I had my sensors moved to my aftermarket rims for non snow months. My factory steel rims have the snows with no sensors. In Summer no prob, but in winter the TPWL will start flashing for less than a minute then shut off until I restart the car. Sometimes it will come on and sometimes it wont but it always goes out after flashing. Is this typical?
#8 | |
Oops I said TPWL (tire pressure warning light) when I meant TPMS.
Even when I go on long winter trips for several days the light will often start flashing for less than a minute and always go out. Normal too?
There are so many really smart people here clearing every hurdle placed before them that I am awe struck by it. I am very fortunate to have stumbled into this awesome community.
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
I've bought a lot of "stuff" I intended to add/mod to my Yaris, this was the first mod I did. To me it is mandatory. The TPMS is a sales gimmick, nothing more. The batteries in the sensors will eventially go bad, you must have have the ability to swap rims without an idiot light.
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
Here is another way to implement CTScott's mod to make the TPMS light stay off no matter what. It's electrically identical, quick, easy and leaves no readily observable evidence of "tampering". It's also a reversible mod. You'll need a small side-cutter, a soldering iron and about 10 minutes of time.
The three pictures should say it all. |
^Nice!
Totally out of view for those worried about it being seen when they go in for warranty work. |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
I gotta do this .. mine still doesn't work right and this is with the resistors. Not working for some reason, but Domo blocks the view of it so it's not really annoying.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
I'm finally ready to do this fix. The switch option requires that the snipped brown wire that is attached to the connector be grounded, while the upper part is wired to the switch. Right?
No, there is not a ground connection. With the switch, you are either leaving the brown wire connected or connecting it to the +5V line.
In post #115 the diagram shows the brown wire is cut. The upper part you have pictured connected to a blue line going to one side of the switch. On the other side of the switch there is a blue line that splices to a white wire. The portion of the brown wire that is attached to the connector you show a blue line attached to it. That blue line terminates at a black dot. If the black dot doesn't indicate a ground then what does it indicate? There is no mention of a +5v line in that diagram. This simple diagram isn't simple to me.
| Tire pressure sensors | Tink1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-21-2008 06:53 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
