#1 | |
The black dots just indicate connection points. What the diagram below shows is that the "common" for the switch goes to the wire that heads up to the cluster and the two "poles" of the switch connect to the brown wire (for normal operation) and the white wire (for bypass operation). So, the switch is simply connecting the wire up to the cluster to the output of the module (the brown wire) or +5V (the white wire). In your post where you mentioned ground, I just wanted to clarify that there is no ground connection with the switch, as making such a connection would instantly pop a fuse.
Going Retro
Drives: '09 Tacoma | '90 Tercel Join Date: Aug 2010
Correct.
![]() Drives: 2008 Yaris Join Date: Jun 2013
I tried the mod today but with no luck. The warning light is still on after I connected brown to white. Please see the attached pic. My yaris is a 2008 one.
Thank you. |
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
I just did a search of this entire thread and there is no mention of a +5V. So how am I supposed to know what a +5v is?
The "common"? "Bypass operation"? I'm not familiar with such terminology. If you would could please explain it using "man in the street" terminology. Like saying "white wire" rather than complicating it by adding the +5v term.
Again. If the black dot connected to end of the blue line that connects to the brown wire attached to the connecter is a connection then what is it connecting to? Not the blue line going to the switch. I think CTScott is so technically advanced it is hard for him to simplify his explanations to the point where everyone can understand them.
#8 | |
The lines with the black dots represents the switch. The switch is a single pole, dual throw switch, which simply means that it takes one wire and connects that wire separately to two other wires. Depending on which direction the switch is flipped in, it connects the center to one side or the other. The picture below shows an example of a SPDT switch. You would attach the brown wire going up to the cluster to the center of it, and then the other side of the brown wire to one of the outer pins and the white wire to the other outer one.
So all 3 dots are switch connection points with the brown from the connector connecting to the center post?
How long do the wheel mounted TPMS sensors last before their batteries fail?
This guy knows everything. Sheese!
Now I'm going switch hunting at the auto parts store.
やりすぎだ~
I got my switch from radioshack, might be cheaper than auto parts.
Yes, CTScott knows everything - I mean EVERYTHING! So glad he is here and owns a Yaris. |
Imagine the hours CTScott must devote preparing all this material for our benefit.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
![]() Drives: '08 3DrLB. Join Date: Sep 2010
Many thanks for this mod. this will save me serious $ whenI put rims on my '08 LB.
| Tire pressure sensors | Tink1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-21-2008 06:53 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
