Old 11-27-2008, 06:59 PM   #1
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Year 2008 (Purchased April 08)
Model Liftback w/auto & conv
Color Bayou Blue
Mileage 21,750 miles (yup, I do alot of driving)
Problems none
Old 11-27-2008, 07:35 PM   #2
Kal-El
Kal-El's Avatar
Originally Posted by b_hickman11 View Post
It was damage from Hurricane Ike. Insurance fixed it and FEMA paid my deductable.
All of the shingles on my apartment complex blew off during Ike and it acted like sand paper on my paint when the shingles hit it.
Ahh, I do remember you posting about this a while back. Your first post just sounded like you just painted it because you didn't like the paint.
Old 11-27-2008, 10:27 PM   #3
rg570lvr
Drives: '08 Yaris MM 3d Lb, auto
2008 3door Lb, Meteorite Metallic, 9,130 miles.... it came with factory installed cruise control which I don't use because it pulses the gas instead of locking at one speed. The dealership won't fix it because they claim they can't "duplicate the problem" and everything is fine. Anybody else that rides in my car notices without me saying anything, but the dealership says it's ok. Brought it in many times and can't get anything done. Besides that I love my car.
Hackers suck!
rg570lvr is offline   Reply With Quote
Old 11-27-2008, 10:32 PM   #4
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
when i drive about 60 ( i dont have cruise control) it seems like its pulsing .. strange
Old 10-09-2011, 11:12 PM   #5
paperboy
Drives: 2007 Yaris 5 Door Hatch
sounds to me like you're just setting your cruise control at a speed where your car can't decide what gear it wants to be in. add or deduct 3-6mph and it should stop imo
same with the guy experiencing pulsing when he rides right on the line of 60mph
paperboy is offline   Reply With Quote
Old 10-10-2011, 12:23 AM   #6
Chuck G
Drives: 2010 Yaris Sedan
How do you set cruise control when you don't have it?
Old 10-11-2011, 07:31 PM   #7
paperboy
i don't follow...
to clarify what I'm saying:
the first guy has cruise control. he is setting it at an rpm that his automatic transmission can't decide on 3rd or 4th gear
the second guy has no cruise control. he is manually holding the rpm at that same point (roughly) with his foot on the gas and his tranny also can't make the choice
it's the same thing only in one case the cruise control is holding the rpm at a point the tranny doens't like, and in the second case it's the guy's foot.
you change gears on a stick by depressing the clutch pedal and manually changing the gear with the shifter. in an automatic the gears change for you based on the rpm you are using.
if you have a tachometer, watch how the needle moves up, then drops off when you change gear. then make the same manuever, but right where the rpm drops off to change gears, let off the gas ever so slightly and just hold it there. your transmission will wait for your cue to change gears (when you increase the rpm just a fraction) so hit the gas enough to change gears, then let off again. see what happens.
well, my theory is this is what is happening continually to these two guys. the cruise is letting up the gas right at that critical moment, as is this guy's foot.
milking MPGs by going for some imagined sweet spot is a waste of time if you're hovering right at the rpm where your tranny wants to switch. milking mpgs in general is a little silly on a yaris since you're using so little gas anyway. it's the kind of behaviour that might make sense in a truck, but in a small economy car, the difference is going to be so small it's not really worth the effort. not to mention, being distracted by something as silly as your mpg while actually driving is just plain dangerous
so like I said, increase or decrease the rpm by a small amount (by setting the cruise at a higher or lower speed or giving it a little more gas for the guy without cruise control) .
try this out and see if you have positive results and get back to me because i'm interested now
and most of all: listen to your engine. torturing your engine/tranny/clutch/whatever on the quest for 45mpg isn't going to save you any gas money, and in a couple of years, it's actually going to cost you a bunch of cash when you need a new car/engine because you killed your yaris trying to squeeze blood from a stone
Old 07-06-2010, 10:55 AM   #8
brg88tx
Drives: 07 Yaris Sedan, Auto
funny you mention this because my aftermarket rostra cruise does this too. i think it has to do with the dfco engaging when the cruise lets off the accellerator.
brg88tx is offline   Reply With Quote
Old 09-16-2012, 04:17 PM   #9
Idahotom
Drives: 2008 5 sp. LB
Interesting, my aftermarket cruise is the most accurate and consistant I have ever had in any vehicle. It just nails the speed desired and keeps it there, period.
Idahotom is offline   Reply With Quote
Old 04-13-2009, 12:44 PM   #10
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Color Bayou Blue
Problems none
That was in November...... beyond 32,400 now and still not a hiccup.
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
