Please look at the directons on page 3. Based on feedback of mixed results, I changed the resistor value as the original value was causing a valtage drop that put it on the edge, where it would work on some cars and not on others.
#2 | |
I dont know if this makes a difference but i Dont have a brown cable on mine I have a white with a black stripe were that brown one is on your write up. Any suggetions. thanks for all your help. |
#3 | |
If your connections are in the correct place, try measuring the voltage on the "brown" wire with the switch in both modes. With the TPWS connected (and the sensors not present) you will read ~1 VDC. Withe the TPWS bypassed you should read ~4 VDC. If the voltage is less than 3 VDC, the light will remain on. If you do measure less than 3 VDC, you will need to change the resistiors to 150 ohm, 1/2 watt ones. |
#4 | |
I'll try again this weekend thanks. |
![]() Drives: '08 liftback mt Join Date: Nov 2008
Installed the 150 Ohm resistor harness yesterday and no more light!! Took a 60 mile drive last night and 3 mile work commute today and all is still great!
#6 | |
| Tire pressure sensors | Tink1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-21-2008 05:53 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
