Old 03-11-2011, 10:36 PM   #1
onizuka
Drives: Yaris Blk 5 Drs RS
This thread is getting VERY interesting. Yes, I am the original owner of this thread. Back in 2008, I was complaining about how my sensor failed in 2007 on one side, and 2008 on the other. Today as temperature is warming up, guess what...my sensors failed again. Back in 2008, I got them replaced by Toyota. It appears that the new/modified/improved/watever sensor hardness is no more protection than the original one. My car has only 130000km, not bad for a car that is purchased since 2005. This is my first and my last Toyota!
onizuka is offline   Reply With Quote
Old 03-12-2011, 04:31 PM   #2
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
i just discovered this problem on my car this winter, occassionally the two lights would come on and the abs would be disengaged.
we had A LOT of snow this winter so i thought maybe snow was getting packed in around the sensor or something, the problem went away for a long time but now that it's getting warmer it's actually getting worse.
my car is an 06 with 125,000 kms on it
stuffy is offline   Reply With Quote
Old 03-14-2011, 04:09 PM   #3
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
As soon as I posted on this thread my lights went off, so "no problema"
D.
CLA 250, 4MATIC
Old 03-15-2011, 07:23 PM   #4
s2kap1
Drives: 10@4run
sh!t happen to me today,abs+hand brake lights go on 06 HB RS , will Toyota will fix the problems with NO charge
s2kap1 is offline   Reply With Quote
Old 03-16-2011, 11:56 AM   #5
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Good luck with that. I think both sides are a $1000-1200 repair.
devinlamothe is offline   Reply With Quote
Old 03-16-2011, 03:27 PM   #6
stuffy
stuffy's Avatar
D.
it will probably come back on...mine did the same thing
i talked to toyota canada...apparently they have no idea of such a problem with the yaris
called my dealership and they are definitely aware of an issue, they said it's possibly moisture getting into the sensors, i have an appt on friday so i'll see
Old 03-17-2011, 12:24 AM   #7
onizuka
Toyota is in full denial mode on this issue. Just like they did on the accelerator problem on Camrys and Lexus. How can they not know about this issue? the parts are in constant backorders...."geeezz...why would this parts becoming so popular? as popular as the Netz emblems..."
Old 03-17-2011, 01:11 AM   #8
derickveliz2
I'm about to remove the camber kit in the rear axle, so I have to disconnect the ABS "Again"! (I've done it at least half a dozen times.
It's very easy to do, but it's very easy to break them too.
D.
CLA 250, 4MATIC
Old 03-17-2011, 01:23 AM   #9
yaris2010RS
yaris2010RS's Avatar
hey...if the issue is the connector cant u cut them off and hard wire them together?
Old 03-17-2011, 02:20 AM   #10
derickveliz2
Thumbs up
Yes it could be done, I would like hear TCScott's opinion first.
Once I pulled too hard and I end up with 2 single wires in my hand, put them back in and it was ok. I was ready to cut and solder the wires my self.
D.
CLA 250, 4MATIC
Old 07-28-2011, 11:34 AM   #11
Duncan Ashworth
Drives: 2007 Toyota Yaris
Unsafe 07 Yaris
Total cost spent to date related to the faulty ABS brake issue is $6000+- and counting. Sooner or later Toyota Canada has to issue a recall notice for this major safety defect. I'm amazed no one has been killed yet! We have spun around 3 times because of a locked rear wheel. Wow! unbelievable. I recently filed with Transport Canada. I will be undertaking legal action unless Toyota Canada fesses up.
Duncan Ashworth is offline   Reply With Quote
Old 07-29-2011, 04:43 PM   #12
devinlamothe
Good luck with Transport Canada - I filed almost a year ago and got no response.
My ABS lights have been on for a couple of years now ... I don't really care to spend $$$ to fix this.
If you find a way to solder them directly to the hub without damaging anything, can you please post some pics of what you've done? I would like to do the same and then apply a crap-ton of weather proof silicone to seal the bugger.
Old 07-29-2011, 08:56 PM   #13
"G"
Drives: 2007 Yaris Hatch
In order to solder them directly you need to remove the hub anyway, so you might as well install a new one.
"G" is offline   Reply With Quote
Old 03-17-2011, 01:58 AM   #14
auxmike
auxmike's Avatar
Glad I don't have ABS on mine, seems like a big hassel...
Old 03-17-2011, 06:11 PM   #15
Dave
Drives: 2007 Yaris Sedan
How would hardwiring around the sensor solve the problem?
Maybe I'm not understanding your idea properly.
It seems to me that if you were to do that, you'd still be driving a car without a functioning speed sensor that no longer has ABS. You might as well just pull the fuse and not cut any wires. I'd hate to have to explain to my insurance company that I got in an accident because I cut a bunch of wires off my brakes.
Dave is offline   Reply With Quote
Old 03-17-2011, 06:20 PM   #16
speed sensor -> connector -> wires
proposed solution:
speed sensor -> wires
Since the issue is corrosion in the connector, the idea put forth by yaris2010RS is to directly bypass the connector and hard wire direct to the sensor.
Old 03-17-2011, 06:52 PM   #17
Dave
Riiiiight. Sorry, it's been a long day. My bad.
Old 03-18-2011, 12:07 AM   #18
stuffy
stuffy's Avatar
i'm writing a letter to the wheels section of the toronto star regarding this, perhaps if more of us did that we would get some attention and therefore action from toyota canada.
here's the email for the editorial staff of the wheels section if anyone else feels so inclined:
wheels@thestar.ca
