#1 | |
![]() Drives: 2007 Yaris LE Join Date: Jan 2014
Thank you |
I would go back to your undercoating people, as it sounds like they coated the rear sensors.
#3 | |
Thanks again for replying so quick. Always appreciate your words of advice. I live in a different city now and visiting the under-coaters is not really an option for me anymore. Would I have to remove the rear wheels and get intimate with the ABS sensors? Is there a guide/manual that shows how to remove the rear sensors? I got the outer shell open but I don't want to tinker with the wires unless I know exactly how to remove the connectors. Thanks |
#4 | |
You have to completely remove the rear hubs to get to the sensors and special tools are required to remove the sensor from the hub to get to the business parts.
I've had the ABS warning light come on last year. First time after 8 years of abuse. The problem seems to be salt is able to find its way into the connector, and make improper contact with the ABS sensor on the hub. Filled it with dielectric grease and it never came back again.
Sent from my ONE A2005 using Tapatalk |
![]() ![]() Drives: 07 Yaris 4DR Join Date: Jun 2009
My ABS and ! light came on this week. I took it to the dealership to diagnose and they came up with rear left, and front right. I said hold off on the repair (and they wouldn't inspect my rear right for some reason). Picked the car up, and the light has been off. Took it to another mechanic I trust, and he said to drive it as-is until the lights comes on again.
My ABS and ! light have been coming on more often. I took it to a small mechanic I trust to diagnose.
ALL my sensors showed up on the history, which led my mechanic to think it wasn't a sensor problem. The mechanic cleared the codes, and went for a drive. My right rear sensor came on immediately. I'm going to drive it for a week or so, and go back to see if the other sensors will come up again. |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
Cars don't fix them selves.
Took the Yaris back to my mechanic. The rear right, and ONLY the rear right, ABS sensor came up on the scan. I'm going to replace the rear right and the harness next Saturday. Hopefully that'll be the end of things.
![]() Drives: 2008 Toyota Yaris Hatchback Join Date: Apr 2016
Is there a video tutorial on how to do the cleaning and grease trick using WD40 and dielectric grease for the sensors? Or can anyone make one? I'm not very handy or knowledgeable when it comes to cars. But this trick seems to be working for a lot of people having the same problem I am. I've already brought my car to the mechanic twice, first time he replaced the sensor, second time he replaced the bearing. Still no luck, can't afford to keep replacing things if its not going to solve the actual problem! Any help would be greatly appreciated!
Is there a reason the mechanic only replaced one sensor? Any of the 4 sensors could cause the issue so replacing one is good, but not if the other 3 are also causing the issue
He showed me the old sensor he replaced and I could see it did have some noticeable corrosion. He didn't mention any of the other ones having problems with them. I guess ill have to bring in my car again and have him try to do this clean and grease trick to see if that fixs the problem. Otherwise Ill have to replace more sensors.
![]() ![]() Drives: '15 Dodge Challenger Join Date: Aug 2011
had mine go 4 or so years ago, was told it was $700+ to repair so i pulled off the gauge cluster and covered the lights with electrical tape behind the face. Last year when i replaced my front bearings i noticed a ton of corrosion on the speed sensors.
Really a problem that should have been addressed by Toyota. :( Edit: never really needed the ABS, just buying some good tires and brakes and my little Yarii can plow through winter like no tomorrow |
My ABS and ! light turned off this week with the warmer weather.
Despite that, I went through with replacing my rear right wheel bearing and ABS sensor harness. Cost me about $450. Fingers crossed the issue doesn't return next winter. |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
My ABS light came on yesterday for about 10 minutes, then it turned off. Glad to see I'm not the only one with this issue.
Subcompact Culture: The Small car blog |
![]() Drives: Toyota Yaris 2007 Join Date: Dec 2016
My 07 Yaris Sedan base model experienced ABS light on in February 2014. It was a particularly cold winter. It was out of warranty, and the repair at Canadian Tire cost $1177 CAD. Both rear sensors and their harnesses were replaced. Haven't had problem since.
![]() Drives: 2005 Yaris Join Date: Aug 2017
is there anyone with used connectors and hub/bearing assemblies? whats the cheapest prices anyone can find these parts for?
![]() Drives: 2007 Yaris Join Date: May 2017
I know this is an old thread but wanted to share appreciation for the advice. Had ABS and brake light on this week. 2007 sedan, in Calgary; particularly slushy recently and brakes were still working but no ABS, so this thread sounded like it could be related to the problem.
Per advice I took rear wheels off and checked sensors, sure enough they were absolutely covered in salt. Cleaned and applied some dielectric grease. Now lights are off, tested brakes on a patch of ice and ABS working fine. Fingers crossed that this is a lasting fix. |
