#1 | |
#2 | |
Yeah, I'd feel reeeeeeeeeal safe with that much of nothing making contact with the road. On a side note...most tire machines say not to seat the bead of any tire at a pressure exceeding 40 psi...but had an extra 20 psi and get out on the freeway... |
#3 | |
![]() Drives: Yaris Hatchback `08 Join Date: Nov 2008
i had a set of Bridgestone Winterforce tires put on the Yaris for the winter. I checked the pressure and it's at about 35 psi. The max on the sidewall of the tire said 44 psi. I called the Bridgestone/Firestone tire dealer that installed the tires and asked them why so underinflated. They told me that the best thing to do woudl be to stay within what the car is rated for (whatever it says on the door label)
I think it's a load of crap, cuz I'm losing about 100 kms per tank ever since. Can I inflate to 44psi? |
#5 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
I run 36psi
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I am not sure where all your venom comes from b_hickman11, but it is uncalled for. Your experience, if truthful and accurate, is unique in all that I and thousands of others have learned and experienced at higher pressures.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
So its a fluke? Right.....
Yes, I believe it is either a fluke or a misrepresentation by those that told you it was the fault of the higher pressure in order to escape their own culpability for a substandard product.
#10 | |
Beast
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
The Martian
Listen center tread wear can easily be tested the same way I use to test my tires for roll on turns. On a dry day take a piece of sidewalk chalk and just make 4 or 5 1inch-2inchthick lines from the sidewall and across the tread. Drive your car for just a mile or less and check to see where the chalk has been worn off. I bet that at 60 PSI you will see substantial center tread wear and at 32 if you have taken a hard turn will find that some chalk has been worn off of the sidewall!!! Easy test that I owe Loren for helping me find to use on autocross
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
Just call me Ray, better?
well i put 100 psi into my 205/40/17's... it hasn't popped yet...(just so you know this was a joke)
When the salesman delivered my Yaris to my home he showed me these Green Tire "Caps"(where you put air in the tire ) He said the tires had nitrogen in them! That they would hold the pressure better than air? So far, So good! And I think someone special ordered this car and then rejected it...Thank goodness for unanswered prayers.
I had ordered a "sport" 3 door liftback from a salesman in New Orleans! I waited three months for my Sport Yaris to come in. THEN I LEARNED....Japan does not ship the Sport to America (they could now? but not then-three months ago). I then ordered my Yaris from Slidell LA and told he salesman to find me the closest car to the Sport; to which he did. It came with all the airbags/cd player/mp3 ready/Automatic/tinted windows/15" wheels and sporty rims. I added the GPS/Backup Camera/Viper Alarm/Scan Guage/ lots of trim and if I could find out how to make the GARAGE I once had no this site I would take pictures...I love the color..Meteorite Matellic..I sold my new Lexus to buy this darling car...and the only thing I miss is the cornering lights my Lexus had...Nothing else.... If you know how I can make my Yaris Garage again I sure would appeciate your telling me.. |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
generally i run 5-10 psi under max depending on the tire...keep in mind, the more the pressure the less the contact patch of the tire. while that smaller contact patch means less resistance and therefore better milage, it also hurts your traction if you inflate too far...and thats not so good.
just watch your shift points and keep your foot out of it, these cars can get 40+ mpg in stock form with ease if you take it easy.
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
BILL , you can't win . I've tried and it gets us and others more rild up . We too keep tires at 34 p.s.i. ( <or> lb. ) and get an overall average of 38 m.p.g.. If they want to speed up earlier wear on their suspensions and put themselves / others at risk that's their decision . Yeh can lead a horse to water , but yeh can't make 'em drink . NEYYYYY
╚══════════RN
THERE CAN BE ONLY ONE -- RIGHT ANSWER! YOU MUST ALL FIGHT TO YOUR DEATHS!
Seriously though, why does everyone need to be so right on this? The OP just wanted to know what pressures you run your tires at, not your life story. Me, I keep 'em at 37psi. Maybe will go up to 40 in the future.
#17 | |
I'll try to be right on everything: Toyota says 32psi, I'll put 32psi in the tires. ![]() They also say 5w-30, so I use 5w-30, etc... I might start thinking like a rebel next year and switch to 20w-50 (7qts), going down to 11psi, using green coolant, R-12 freon, bias ply tires, ATF in my 5-speed, torque my lugnuts to 200 ft/lbs, do OCI every 20k miles...or not...Toyota was right on all the other specs, don't know why they'd put a tire information label on the car that had inaccurate info on it; they didn't. OP, Toyota says 32psi...believe Toyota, or believe people that decide to nearly double that number
Albino truck smasher
Drives: '07 Yaris LB Auto Join Date: Oct 2008
Had them at 45 psi for about 6 months, and have now had them at 50psi for the last 4 months. No problems to report, and while I haven't noticed a significant increase in fuel efficiency, my rolling distances have increased when not using gas.
I have actually hit a few curbs and ruts that blew out a set of tires I had before at 32psi, and they didn't show any damage when I hit the same curbs with my current 50psi tires. |
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| Tire Pressure Max | deebrown | DIY / Maintenance / Service | 82 | 08-10-2007 09:44 AM |
| Tire Pressure and Gas Economy | KittenRD | General Yaris / Vitz Discussion | 11 | 01-25-2007 10:54 PM |
| Tire Pressure | slvryaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 11-05-2006 12:37 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
