Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
Well i could go dry, but i wouldnt even dare push a 50 dry shot threw this engine since we have no tuning out for us...Also with a Wet im alittle worried about the stock Mani puddling and me getting a good'ol backfire. We'll see how it goes once install rolls around. This will be my 7th nitrous setup ive installed.
You think your Yaris is low and fitted LOLzzzzz |
yeah, Im going 35-40 tops wet "single shot", through an injection spacer between throttle body and intake mani. at least untill I have the cash for internals.
Slowy getting there
Never said anything about WHP base line he was spraying a 75 shot when he spun the rod. His base line is probably where anyones is with a couple bolt-ons
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
ok so i've read through this whole thread and i'm still not sure what the consensus is on where the best place is to spray the nitrous. is it pre TB or right after or into the intake manifold? would i be fine injecting it into the tubing directly before the TB? i thought i read in one of these posts that someone had successfully done that or recommended it if running a s/c.
![]() I crush you like tiny clown car, because you are clown, yes? |
Bathroom + Laptop = <3
Dry kit you would run it before the throttle body. Wet kit after the throttle body, would you want a pool of nitrous stuck inside if some gets caught on the throttle body and just drips into intake..
a pool of nitrous lmfao dude, since when was nitrous oxide a liquid in it's uncompressed state?
builds up on the butterfly?
frozen water ?
because you guys are DBW, yeah i wouldn't recommend spraying super-chilled air past delicate equipment.. but a traditional setup wet or dry can be mounted pre-throttlebody.
Slowy getting there
Then evaporates. I always thought a dry system was setup at the begining of the intake system by the filter. I believe zex even sells cone filters with a nozzle in them
Slowy getting there
Why do hondas purge their nitros system on their windsheild and have no extra fluids running down it
Mr. Clean
It's not actually "on" the windshield (or at least it shouldn't be). The purge line is usually routed there pointed up so the driver can see it. It's just a quick shot into the air to make sure the nitrous line is fully charged and there isn't any air or vapor in it.
Slowy getting there
I understand what the purge is for. I was only saying that because some of the Hondas that I saw when I lived in Kansas did it on their windsheild not sure why though
![]() Drives: Yaris Sedan Join Date: Jul 2009
I want to buy a nitrous system. Which one is the best for the 1NZ-FE?? Which are the options to choose from? My engine is 100% stock.
![]() ![]() Drives: 05 Echo H/B Join Date: Jul 2009
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Are you using the Zex nitrous management unit (the box) or just a nitrous seloniod ??? I got the zex set-up for cheap but ditched the management unit cause its set up for standard fuel systems that use a fuel pressure regulator which the yaris doesn't have .
Who said Yaris was slow?
Courtesy of Microimageonline.com
NX nitrous kit + 50hp shot = Awesome!! This is my friends car... I took it for a drive last night and got bottom happy if you know what I mean... ![]() ![]() Some pics: |
| Expressions and Explanations thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 0 | 11-09-2008 05:55 PM |
| The Official "Bambo the Yarisworld Traveler" thread (V1) | nemesisz | Off-topic / Other Cars / Everything else Discussions | 3 | 11-08-2008 10:24 PM |
| Is there a thread about..... | Letsrock | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 11-01-2008 12:25 PM |
| Post Whores-aka Yaris chat thread | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 21 | 07-12-2007 05:37 PM |
| Thread request - Yaris is new in the US | makaluch | Cosmetic Modifications (Exterior/Interior) | 1 | 08-13-2006 12:16 AM |
