Old 01-08-2009, 12:40 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Originally Posted by Chupacabra View Post
....and M1 EP seems to be 2nd best
Run it, have engine failure, Warranty wont cover due to oil not meeting manufacturer\'s spec, Now you have to prove to E.O.M. that their oil is bad(ha!) and caused failure, wait 3 years maybe get some money if you are lucky. In the meantime you pay $4500. for engine repair. Sure I want to use that stuff!
TheSilkySmooth is offline
Old 01-08-2009, 12:42 PM   #2
TheSilkySmooth
What am I sayin?! It's gonna be a pissing contest ANYTIME you have an engine failure. Probably the same outcome too.
Old 01-09-2009, 11:50 AM   #3
Chupacabra
Drives: 2009 Yaris liftback
Bullshit. When I went to Toyota....they have a whole entire shelf full of Mobil 1 5-30 and that is what they use when a customer requires synthetic oil. There is no way that if there were an engine failure, they would not honor the warranty due to the use of Mobil 1. They can only check to see the viscosity is correct and the level is correct.
Chupacabra is offline
Old 01-09-2009, 12:54 PM   #4
TheSilkySmooth
The Center Having and selling M1 is irrelevant to this argument, the centere is UNAWARE of the oil being out of specification as are 99.999% of drivers and 90% service managers. If the oil is at fault, the Oil MFG will have to pay and there may be BIG delays in recuping uyour losses. Naturally, Toyota WOULD have to prove that the oil was out of spec and not you, but if they are ShArKs they may give you the ould "run around" if you are ill informed and dont have a lawyer standing next to you. Now, typ they would only perform a viscosity at temp and TBN to certify the oil as OK. But if there is "proof" out there that M1 does not meet sl/sm then Toyota has the upper hand and they can deny warranty claim - IF it is proven a given MFG run of that the oil is NFG. In our world, I would hope MY toyota service centre would just fix the motor if the oil level is good and I have proof of last OC.
ps: I would also not expect to see any failures with this sequence iva test being not met. You may just see some higher wear numbers thru the OCI, if any.
-Papa
Old 01-12-2009, 09:29 PM   #5
SilverGlow
Drives: 2007 Yaris Hatchback
You continue to bolding speak lies, nonesense, and your bravado proves your ignorance.
Using EP will not cause engine failure. It has never caused engine failure. It is too bad that there are many newbies to cars that could read your BS and think it is fact. I just hope that most of the people reading your flippant sarcastic comments see past your know-it-all attitude and lack of knowledge.
And I'm not even a M1 EP user....
SilverGlow is offline
Old 01-12-2009, 10:26 PM   #6
auxmike
auxmike's Avatar
I swear this must be "Grumpy in NH".
What ever happend to him?
Yeah, don't feed the trolls, boys.
auxmike is offline
Old 01-13-2009, 08:38 AM   #7
1stToyota
1stToyota's Avatar
You got pretty close to speaking that same lie again. Engine failed due to an oil related issue in a late model chevy pickup that used nothing but M1, Mr know-it-all.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
1stToyota is offline
Old 01-13-2009, 12:35 PM   #8
TheSilkySmooth
I would respond, but you are too ignorant to formulate an argument using logic. So have a Bad day
Old 01-13-2009, 07:12 PM   #9
auxmike
auxmike's Avatar
...and the beat goes on......
auxmike is offline
Toyotaland Spring Meet April 21, 2007 MtyMseHArmer Rocky Mountains / Great Plains 13 03-31-2018 02:31 AM
YW Florida Meet! Help! Sabretooth Southeast 127 12-19-2008 02:04 PM
Lower Mainland Yaris, Echo, Fit, Mini, meet mojoyaris Canada 24 11-02-2008 01:16 AM
Breaking in a new Yaris yaris_the_walrus DIY / Maintenance / Service 38 09-12-2007 11:02 PM
MONTHLY YARIS AND ECHO MEET PRIOR TO JOINING UP WITH THE TOYOTA NATION MEET Sway84 Canada 11 08-30-2007 06:10 PM
