![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
When you said you dropped it 2 inches. Did you undo the the motor mount bolts?
Yaris GSR LOL
Drives: 07 Yaris Hatch Join Date: Apr 2007
yes, just on the passenger side. both or at least there were 2 on mne
07 Yaris hatchback purchased in Dec '06. April 2015 and 103k miles, brakes finally needed changing, original battery finally died. I love this car. |
![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
Did you drain coolant or merely have to fill it back to acceptable range given the amount that leaked from the pump?
ttt
Drives: Yaris Join Date: Jul 2014
Yaris Verso 2000, I loosened the 2 top bolts on the engine mount and the nut on the underside of the mount a couple of turns, I then got a nail bar and some wood and levered the engine, this shifted the engine enough so the pump came out easily.
Thanks for the original guide |
Whats a nail bar?
Drives: 07 yaris Join Date: Jul 2012
I just did my waterpump on my 2007 yaris two weeks ago i didnt had to loosen the two top bolts from passenger side mount,I had enough room to take out and install the waterpump,I just took the waterpump pulley off.
![]() Drives: 2007 Yaris Join Date: Jul 2014
Water Pump Replacement
I just changed out the water pump on our 2007 Yaris at 190,000 miles. It never leaked a drop but began making a disturbing noise that was very difficult to track down. After referring to many posts on Yarisworld, I felt confident the noise was in the pump even though it felt fine when the belt was removed and the pump was turned by hand. The only additional comments I would make are as follows: I never had to lower the front of the engine by 2"; in fact, I didn't lower it at all. The pump can be removed and the new one installed by carefully turning and twisting it a bit.
I bought a replacement pump and a metal gasket from Auto Zone and everything worked out perfectly. Total time to replace the pump and get the car running again was 2 1/2 hours. |
#9 | |
Good point. I found that unbolting the AC tubing mount, that sits by the pulley, also helps with being able to remove it without lowering or raising the engine.
#10 | |
![]() Drives: '09 Yaris 3dr HB 5sp Join Date: Aug 2009
Did you buy the Duralast water pump (AWP-9187)? How many miles have you driven since replacing the pump with an aftermarket? Any issues or recommendations?
"Never argue with an idiot. They drag you down to their level, then beat you with experience." |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
Mine has 200k and is not leaking yet. But I did flush my coolant at the recommended service intervals and only used toyota pink fluid.
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| DIY: Yaris LB Halo Led Projector Headlights | goku87 | DIY / Maintenance / Service | 37 | 11-15-2013 06:23 AM |
| DIY Requests. | TinyGiant | DIY / Maintenance / Service | 13 | 10-29-2008 10:39 AM |
