Drives: 2009 Yaris liftback Join Date: Nov 2008
Everybody has a story...and all are valid. At the end of the day, the bottom line is that, if you can afford to, change the oil as often as possible and preferably at the well known intervals. If in doubt...follow the owner's manual at a minimum. The irony is that you can't afford NOT to change your oil often....it's the cheapest maintenance you can buy. The dealer has over-filled my wife's Scion twice and since the oil changes are free....I bought a fuji drain valve and let the excess out when it comes home. There is no point in addressing the dealer. I highly recommend oil changes at home. They are easy, fast, cheap, accurate and great piece of mind.
I use amsoil 0w-30 ss I change the oil every 15,000 mi. If you go to the amsoil site they have a lot of info. It may not change your mind, but then again it might. Still worth the time to read it.amsoil.com
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
We had great mechanics for both my BMW and the wife's Passat when we were stationed in Germany. The Passat went to Rittersbacher VW in Landstuhl (on the B-40), and "Herr Kaprowski" was recommended to me by the guy I bought the 318i from.
And I do miss being in Germany. I was just in Munich and Garmisch last month and hope to get back there again in a few months. I was last at Ramstein in May 08 for an exercise, it was a great time to be there! Cheers! M2 |
#4 | |
Drives: 2008 Yaris Join Date: Oct 2008
The EPA wants reduce Phosphorous content in oils. Phosphorous reduces wear in "tight spaces" under starvation conditions, like in overhead valve assemblies. Phosphorous also "poisons" catalysts in catalytic converters, leading to their expiration. This annoys the EPA, which would like emission control systems to last up to and beyond 100,000 miles (160,000 klicks). So the US EPA has been encouraging oil makers to shift to oils that contain other critical additives, such as Moly Di-sulfide. Will these substitutes work in the long term? Who can say? Molydisulfide is a great grease additive and dry lubricant, but oils are not dry lubricants and do other things besides lubricate. Engine oil serves many functions in an automobile. Besides lubricating the crankshaft, bearings and inside walls of cylinders it also removes heat and combustion products. Which of these functions fails first? I do not know. I do know that Yaris do run kind of hot and do need protection. I rarely go above 6,000 miles on synthetic. To me saving twenty or thirty bucks a year for oil and slightly raising the risk of reduced reliability is not worth it to me. I make a decent living and insist upon a reliable form of transportation, especially as I am out and about into the wee hours of the morning. There is not even the awful practice of pouring oil down storm drains or burning it in incinerators to deter us today. Quite a few firms will recycle old oil, returning it to service. Castrol, for example, uses a lot of recycled oil. So to me pouring used oil into the tanks of Advance Auto or other firms does not cause me any worries. We have a member here who achieved 300,000 miles of engine wear, apparently a lot of it at high speeds. He claims to have changed the oil every 5,000 miles. FWIW. Gene |
#5 | |
Drives: yw calls me douche and racist. Join Date: Aug 2007
![]() ![]() ![]() Drives: 2007 Toyota Yaris S Sedan Join Date: Jul 2007
like you said, "oil is the lifeblood of the engine". I have a yaris with over 300,000 miles on it. why? because I use synthetic oil and i still change 5000 miles or before. don't sacrifice your car's engine to save time or money or headaches! because in the long run it may cause you more time, money and headaches, if you damage the engine.
![]() http://www.youtube.com/watch?v=YnTlNLz9Iqc http://money.cnn.com/galleries/2010/...le_cars/5.html http://www.subcompactculture.com/200...-miles-on.html |
#7 | |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Making a decision without following it with an action is still a fantasy. |
#8 | |
Vroom Vroom Beep Beep
Atleast no one here has tried the Ams 25k mile oil yet. I use it in my Diesel truck once a year changes though its 9 years old and has 4k more miles than my yaris
Ever blown out an R-200 diff god know's I have
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
I don't consider myself 'green' by any means, but (believe what you want on the longevity of the oil) if you change the oil at 15,000 miles the cost per mile (40 mpg / $1.90 per gallon / $25.00 for oil & filter) is $0.0491---oil change is 3.5 % of driving costs. At 10,000 miles oil change is 5.3%, and at 5,000 miles oil change is 10.5% of driving costs.
So.....If you believe 15,000 miles between oil changes is ok, You can save as much money or more than if you drive like a hypermiler. Or roughly you can drive an extra 500 miles for free if you extend your oil change by 5,000 miles (1,000 free miles if you change at 15k instead of 5k). Gamble at your own risk...my warranty is off now so I'm going for the 10,000 mile change.
____________ Old School Cobble Jockey
I.. don't think cost is the issue here man.
If cost is not the issue ... change every 1,000 miles! Guaranteed that your engine will have the best benefit of clean oil.
![]() The "facts" of oil performance are buried somewhere in reports by indpendant and not so independant labs. Everyone is free to pick the "facts" that they choose to go by. ![]() In the 60's I changed oil every 3,000 and engines were still sludged up. Now oils are so much different....the EPA mandating changes in additives for green concerns, is the main source of reduction of oil's effectiveness (trade offs).
Are you even reading this thread?
#14 |
Sorta thought I was! The only reason to spend money changing your oil is to prevent spending a lot more money by changing your engine. Some people think 15k is fine for synthetics, and seems like someone mentioned an oil that claims 25k.
My warranty is up, I drive 30k a year, and my opinion is that I'll drive 5 to 10k before I change my synthetic oil. If you have a different opinion fine. Driving conditions vary for everyone, and that is a big factor. As far as 'factual' info on this, it's sort of like global warming, you will find supporting 'facts' however you think.
#15 | |
IMHO, I don't think oils have much to do with the change intervals. If the oils meet the minimum requirement, it'll then depend on how well made the engine is. Unless you're a Ferrari owner or something. Then that would be a different story. My mom's Nissan Quest went with out an oil change for 150k miles. Thats right, 150,000 miles. Thing ran like crap. My buddy and I had done a engine flush, twice, changed the spark plugs, and it ran like new. It was epic. Go VG30DE. |
#16 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
#17 |
Beast
Well.. The best you can do is tally up info from various cars knowing how often they were changed on a continued basis and see what happens.
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#18 |
![]() ![]() Drives: 2009 Yaris 3 door M/T Join Date: Jan 2009
Here's my experience with oil changes for what it's worth (possibly nothing). FIY I have never used synthetic oils.
1986 Jeep Cherokee 289,000 miles at time of selling, 3K oil changes as recommended, never rebuilt or replaced engine, used many different brands of oil over the years. 1983 Mercedes 240D 394,000 miles at time of selling, 5k oil changes as recommended, no problems at all, used regular Castrol. 2000 Civic HB 222,000 miles at time of selling, 7k oil changes as recommended, no problems at all, always used standard Valvoline, still getting 38mpg when I traded it for my Yaris. Based on my past experience, I think the Yaris will do fine with 5k oil changes. Recommended oil change intervals for passenger cars are always set within a much larger safety range. Remember it's a recommendation, your car will not self destruct if you take it to 5,001 with no oil change, or 10k or even 15K (though I wouldn't suggest trying it). The Yaris is a well engineered, solidly manufactured, quality machine and that's a big part of the equation that often gets overlooked. It's built to last if well maintained. Consider how many oil changes you will do for each 100k miles - 33 times if you change at 3k or 20 times if you change at 5k. Consider how much you spend for each oil change. I do my own and it costs me about $25 each time including filter. That's $500 for every 100k miles with 5k changes or $$825 with 3k changes. I am personally not convinced that the extra expense of the 3k change is warranted for the Yaris. Based on knowing many long term Toyota owners, I just don't see any otherwise properly maintained Yaris blowing an engine at 150k even 200k because someone did 5k changes instead of 3k. These are just my opinions, based on my own real world experiences. Change your own oil as you see fit. To each, his own. Last edited by Havana; 02-04-2009 at 10:52 AM. |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 02:43 PM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-24-2009 12:30 AM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 04:25 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 03:56 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
