Old 10-15-2006, 09:31 AM   #1
03Z33
03Z33's Avatar
Drives: TCR10
Originally Posted by Katana
How did you manage to drift your Yaris???
I need advices!
I fitted a Hayabusa motor in the rear hatch to drive the rear wheels hahaha
The type of track events I take the Yaris too are not drift events, they are grip events. It's very difficult to drift a front wheel drive car on tarmac. In gravel it's another story
I have been known to use the e-brake to whip the car around 180 deg though Drum brakes actually do a nice job of locking up the rear
03Z33 is offline   Reply With Quote
Old 10-15-2006, 02:50 PM   #2
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Thanks!
I am trying to get used in using the e-brake!!!
Old 10-15-2006, 06:02 PM   #3
ChinoCharles
Drives: LB
Second gear usually revs up so high it scares me and I can't gather my balls up enough to grab the e-brake. This cars a riot.
Old 10-16-2006, 12:47 AM   #4
03Z33
03Z33's Avatar
Drives: TCR10
You can place some plastic lunch trays under the rear wheels for practice
Old 10-16-2006, 12:58 AM   #5
SmellyTofu
好多人&
Drives: .
I must say even in standard trim, it's not a bad car to got a thrashing on the track. Apart from the need for a LSD (left foot braking to hold the spinning wheels maybe??), it's quite adequate to pull respectable times on twisty tracks when you compare it to other cars that have more power and some suspension modifications.
SmellyTofu is offline   Reply With Quote
Old 10-16-2006, 02:23 PM   #6
Katana
Katana's Avatar
I agree with the last comment.
In a greek track, a 1.3lt Yaris did the same lap time with a car that had the same weight and 100 more hp.
Old 12-26-2006, 12:26 AM   #7
03Z33
03Z33's Avatar
Drives: TCR10
fixed pics anyone else have any track reviews?
Old 12-26-2006, 02:38 PM   #8
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
cool
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 12-27-2006, 03:46 PM   #9
Katana
Katana's Avatar
Guys I recorded a new video today, but it is vertical and not horizontal.Do u want to see it?Any ideas on how to turn it upside down?
Old 12-27-2006, 04:05 PM   #10
Katana
Katana's Avatar
Check it out!
http://www.youtube.com/watch?v=inU2wGh4SD8
Old 12-28-2006, 03:16 AM   #11
03Z33
03Z33's Avatar
Drives: TCR10
Nice! I feel dizzy now from turning my head
Old 12-28-2006, 04:21 PM   #12
Katana
Katana's Avatar
Thanks mate!
In fact, I improved my personnal best at about 5 seconds!
Old 12-29-2006, 03:15 AM   #13
03Z33
03Z33's Avatar
Drives: TCR10
Originally Posted by Katana View Post
Thanks mate!
That's great! Is it all driving or did you change some parts of the car? What tires do you use?
Old 12-28-2006, 04:40 PM   #14
YarisGuy
Drives: 2006 Yaris
Good stuff man, always good to see our little cars on track
What times were you running compared to the other "slower" cars?
YarisGuy is offline   Reply With Quote
Old 12-28-2006, 05:50 PM   #15
Katana
Katana's Avatar
Generally, the setup of the Yaris helps it to turn better than more expensive cars!
Thanks for your kind words.
Old 12-31-2006, 02:38 PM   #16
Katana
Katana's Avatar
It is all driving, cause a friend of mine gave me some extra useful advices.
Since the last time that I was on track, have only installed a CAI.I use my regular road tires, but I increased the pressure from 30psi to 38psi(front) and 35psi(back).
Old 01-01-2007, 08:59 PM   #17
Pars
Drives: 07 Yaris Liftback
Why increase the tire pressure? I'm guessing it's to keep car from ridding on it's sidewall? And, less pressure in the back to keep the rear end planted...
Pars is offline   Reply With Quote
Old 01-02-2007, 02:32 AM   #18
03Z33
03Z33's Avatar
Drives: TCR10
That sounds about right... since he's probably using an all season type tire lowering the pressure won't do much for grip and upping the pressure will probably help reduce the sidewall flex more. If you run a sticky street tire or an R-compound you will usually do the opposite and lower the pressure to compensate for the added pressure when the tires get hot.
My Review of My Yaris Sedan 2007 David81 New YARIS Purchase Forum 6 09-10-2006 01:48 AM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
