Old 02-08-2009, 07:19 PM   #1
EBoOGie
Drives: 07 yarii
my "ABS" and "Brake" light is on my 07 sedan. ABS is not suppose to be workin when it on correct? A few times when im drivin, and come to a stop, the ABS seems to be working for no reason. ( the abs noise, sounds mechanically clicky. pedals feel soft and spongee, ONLY sometimes this happens.) Conditions were dry, no ice, no water so i was not skiddin when i heard the abs noise kick on. is this the same thing everyone is experiencing?
are you experiencing-
- the abs and brake lights as well as noise?
-or only abs and brakes lights on only?
im confuse
EBoOGie is offline   Reply With Quote
Old 02-10-2009, 01:27 AM   #2
Pars
Drives: 07 Yaris Liftback
im confuse
I also had similar symptoms, the ABS was out of wack and activated for no reason, but this only happened when the ABS light was off. Immidately after the ABS acted-up, the warning light would once again come back on and ABS would be deactivated, which was preferable to the abs pulsing away for no reason.
Pars is offline   Reply With Quote
Old 02-12-2009, 12:49 AM   #3
Former_Neon
Drives: 1997 Yaris LE
Well, I'm still waiting for the speed sensor and wiring harness to come in. My ABS is working again though. The lights have turned off on the instrument panel and all is normal for the time being.
As if Toyota could give a damn.
Former_Neon is offline   Reply With Quote
